1. holes in the rear shock towers where AIRRIDE suspension used to be before i got it
Yeah... ghetto... but no one will ever see those holes if you have them covered up with the OEM panels
2. VERY uneven tire wear due to horrible camber.
On the front right? That must be because they screwed around
with the front mounting holes
3. some meenie in my old apartments decided to hit my driver-side fender and door with his door like 8 times!!!
fenders can be had for relativley cheap.... Where are you located? and what color is your car
4. a previous owner cutout notches in the top of driver-side shock tower where the strut bolts come through to try and rig up some "ghetto camber correction" so they could run dsm 5-lug hubs.
5. master cylinder is incorrectly positioned b/c previous owner did not want to convert the auto brake pedal assembly to manual, so the brake pedal is about 2mm away from the clutch pedal. the clutch is insanely hard to press b/c the master cylinder is not positioned correctly. it is too far down, so i don't have the proper amount of leverage on the pedal.
6. firewall has all kinds of holes in it
guess he never hear of: "Measure twice, cut once"
7. rotors are warped
So are mine
8. interior harness has been cut and spliced to rig up a 1g turbo harness instead of doing it properly with a 61t harness.
or a complete 1G turbo harness
I
