It is currently Fri Oct 24, 2025 4:42 pm
Post new topic  Reply to topic  [ 22 posts ]  Go to page Previous 1 2
PostPosted: Wed Nov 05, 2003 11:33 pm
i fixed sutibans problem with a simple twist of the idle control.
4g61t.com
PostPosted: Thu Nov 06, 2003 1:17 am
Yeah, I know I suck, but my car is soooo much more fun to drive now!!! that 1.8L TB is awesome and I recomend it to anyone that has a 1.5L to upgrade!
01 Maxima VQ30DE
92 Summit 4g63t (Traded to Evo... R.I.P.)
I heard they ride mooses to work instead of driving cars. (About Canadians.)
PostPosted: Thu Nov 06, 2003 7:14 am
Hmmm... May explain why my car wont idle right on the first start. I always have to shut it off and hit the key again, then it fires right up. Otherwise it stumbles like crazy for about 5-10 secs then jumps to normal idle.
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Thu Nov 06, 2003 1:01 pm
Maybe you'll have to. You could at least try it. If it doesn't help any, try to fiddle around w/ the TPS.
Edit: HUH? Why did my post show up HERE?!
Ignore me.
Got rabies?
PostPosted: Thu Nov 06, 2003 1:47 pm
Hmm I wonder if your cable is set a little to taught and leaving your butterfly valve open a little bit.
1990 mirage 4g63t powered. I need a gas tank. HA HA
PostPosted: Thu Nov 06, 2003 2:19 pm
Although I didn't mess w/ my car (yet), I have a similar problem sometimes. Could also need help here. :-?
Got rabies?
PostPosted: Thu Nov 06, 2003 9:36 pm
didnt think of that. :D Gonna have to check...
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
