It is currently Sun Oct 19, 2025 3:18 pm
Post new topic  Reply to topic  [ 302 posts ]  Go to page Previous 117 18 19 20 21 Next
PostPosted: Thu Jun 13, 2019 4:42 pm
Car insured for agreed upon value of 10K, current as of June 4/2019. That is the good news.
Bad news, tow home due to hot restart and running incredibly lean or barely able to run at all. Silver lining - Hagerty car club covers first 80 miles or so, of towing. I ate into that a little bit.
Got the car home and went over it, but by the time I plugged in the laptop after it had been in the garage for a while (but 1+ hr at the break down spot had no effect), the car ran fine.
So, was it fuel related? Some suggested so, and I put on a new OEM cap to make sure that venting function, does exist and no suction was created in the tank system when warm/hot from sitting on a hot day.
I have a new spare gas cap which is a cap-less style as it is called, so the nozzle goes right in the cap, and opens a little flap door - nothing more than that.
I was curious if fuel related problems could be caused by my vacuum routing of the fuel pressure solenoid or if pressure was an issue to begin with and or if pressure after shut down was bleeding off by design (flow versus bleed down to meet oem requirements per some enviro emissions law), and aeromotive says in their literature that they focus on flow and as such, it will bleed down the moment the fuel pump is shut down, and pressure is therefore relieved as it follows into the return tube to the tank.
Decided to open my SX Performance/Buschur Racing style AFPR. Diaphragm torn on one side, fuel bubble popped as the vacuum hose was drawn off the vacuum nipple, and more fuel evident in the cap area where atmostphere alone, is supposed to be.
Backstory to the SX/Buschur AFPR - it is a bolt on affair. Nothing simpler by design - one o-ring at the rail, and some parts inside the FPR to balance and keep things separated. Turns out the no longer produced top SX portion with the bottom section Buschur part (produced by ... see tuners thread on this one), had a new lease on life. Edelbrock was reported to have purchased SX Performance and as such are offering replacement diaphragm/FPR kits. Parts were listed in a thread on Tuners. I found the part numbers and link from Tuners, and was offered on Jegs.com and summitracing.com to name a few. SX performance may still have the parts too as the OEM number in house for them was also listed in that thread.
I believe the part number is as follows based upon my order through Summit Racing.com: "EDL-178010
Fuel Pressure Regulator Rebuild Kit, Diaphragm Type, Kit
(Mfr. #: 178010)"
I will add some pictures to show TB work, FPR issues, and ISC stuff. This may take some time.
PostPosted: Thu Jun 13, 2019 5:34 pm
Pics. The ISC show was the wrong type, in that the tip not shown, was the wrong shape. It should have been skinny and long, versus the flat stub like one as shown from the other side.
I did install socket head bolts that allow access with allen wrenches or ball socket extensions for use with short ratchets. This was especially good for the TPS, and adjusting it without needing to find space for an 8mm wrench end or a JIC head screw driver (remember all Japanese cars of this era use JIC type bits, NOT Phillips!).
Shown would be my SBC kevlar clutch versus the same model that had issues with rivets stampings and even had the better Exedy center section, but unfortunately couldn't use that one. It had to go back to keep the one with no issues.
PostPosted: Thu Jun 13, 2019 6:00 pm
Flywheel before sanding to match Tim Zimmers recommendation for grit prep.
Removed and proved the FIAV was moving from freezer cold, to 90 C and up.
All channels cleaned and reinstalled FIAV cap and internals with blue loctite on the threads of the cap.
Cleaned up the OEM ISC as pictured with silver metal cap. Had at least on spare hanging around too ...
PostPosted: Thu Jun 13, 2019 6:29 pm
90 DSM 60mm turbo throttle body is identical to a 1989 Mitsubishi Mirage turbo throttle body. The only difference is in the bore or lack there of through the center, and the corresponding throttle blade/plate change to suit.
Should I ever install a newer updated ISC, I would be asking the company that made this adapter to check out their connector stock, as I had to sand and file the ever loving jebus out of those areas that came into contact with the OEM connectors, in the worst way. It works as it should now, but the plastic was bowed out considerably and all around.
How my system is configured, wire locations, etc. Remember that 1989 Mirage Turbo wiring is identical to 1990 DSM turbo wiring!
PostPosted: Thu Jun 13, 2019 6:43 pm
SX Performance/Buschur Racing setup - complete with torn diaphragm!
This might explain my grams per second reading high and my maf comp being a little off where it was last season.
Vacuum leak, yep ... but fuel then being ingested into the intake manifold where it should not be!
Sealing up the vacuum port threads with a little OEM approved thread sealant.
PostPosted: Sun Jun 16, 2019 9:33 pm
Every one of those I've ever seen leaked and people have nothing but issues with them, it is also near impossible to get another diaphragm.
Also I can't see any of your pictures, every post has "You do not have the required permissions to view the files attached to this post." attached at the bottom of each post?
Joey Santiago
2003 Lancer Evolution 57k original miles
1992 Montero LS
1989 Plymouth Colt GT (AWD project)
1989 Dodge Colt GT
PostPosted: Sun Jun 16, 2019 9:47 pm
I logged in and all pics are up. That said, are you logged in when you can’t see the pics?
We will see what happens with a replacement diaphragm. If it works, hurray. If not, I had to try it first before installing the aeromotive.
PostPosted: Sun Jun 16, 2019 9:52 pm
it says that for me also
PostPosted: Tue Jun 18, 2019 6:55 pm
Logged in?
PostPosted: Wed Jun 19, 2019 3:26 pm
Joey Santiago
1992 Montero LS
1989 Dodge Colt GT
PostPosted: Wed Jun 19, 2019 8:00 pm
Strange. I get that message when viewing as a guest, but it all works as it should when logged in. I think all the attachment photos work that way, once uploaded to the site.
Maybe this a good question for Nate.
PostPosted: Mon Aug 26, 2019 6:07 am
I'm logged in. Don't see the pics either.
DRCOLT
1989 3g Colt GT turbo w/4g63t
PostPosted: Mon Aug 26, 2019 11:42 am
That’s strange.
I would contact natas, because permissions should be okay for anyone to view the pics.
PostPosted: Mon Oct 07, 2019 9:34 am
1484 views to go, and this build will have hit 100,000 views!
PostPosted: Sat Nov 23, 2019 3:03 am
Now 💯 k views certified!
