It is currently Mon Oct 27, 2025 5:41 pm
Post new topic  Reply to topic  [ 105 posts ]  Go to page Previous 13 4 5 6 7
PostPosted: Mon Oct 08, 2012 9:37 pm
would dsm/gvr4 knuckles on an elantra still need the camber plates? and what about dsm knuckles and struts?
PostPosted: Wed Nov 21, 2012 9:01 am
I did that swap on my old hatch, and plan on doing my sedan here in the next few weeks. I just drilled out the Gvr4 hub to accept the CSM tie rod the correct way. So the hole in no longer tappered. I had absolutly NO bump steer. and it worked well.
Has anyone confirmed that this works?
I read this thread after installing GVR4 knuckles/hubs/brakes on my car, and the steering is horrible. I'm hoping to be able to mod the GVR4 setup to make it work correctly. If not, I guess I'll have to go with Expo knuckles and swap everything over.
1989 Mirage Turbo w/4G63T
1991 Mazda MX-5 (UK spec)
2018 Hyundai I30N
PostPosted: Wed Nov 21, 2012 10:34 am
My son just converted his GVR4 to 5-lug, so I have a set of VR4 knuckles. I'm going to try this for sure.
PostPosted: Thu Nov 29, 2012 10:41 pm
BUMP! Anybody know if this works?!
2018 Hyundai I30N
PostPosted: Fri Nov 30, 2012 8:16 am
I would not recommend drilling out the taper. I cut the tie rod mount off,flipped it over and welded it back. Before all the cutting, i made a jig to make sure the tie rods end up in the same place, just upside down. Works perfect. Pictures are in my build thread.
PostPosted: Sat Dec 01, 2012 12:52 am
The only knuckles that will work without inducing bump steer or doing something like redrilling the tapers are: Expo, Vista Wagon, and 4th gen CSMs. The 4G CSMs are 4x100 bolt pattern though. This has been discussed at length, in this thread even. Why people even consider screwing around with anything else is beyond me. Drilling the tapers through greatly reduces the surface area on the connection between the tire rod end and the knuckle. This will cause all of the stresses transferred between the two parts to be concentrated to a very small spot. Unless you inserted a new tapered section... Totally not worth the risk or the labor in my opinion.
I've worked with both 3G and 4G CSMs first hand and have pulled 4 sets of Expo/Vista knuckles for CSM projects.
PostPosted: Sun Dec 02, 2012 1:51 pm
OK, so I guess I'm going to get some Expo knuckles. Now, which Expo knuckles work? Or all they all the same? (awd/fwd, w/abs or w/o abs, 1.8/2.4, etc)
2018 Hyundai I30N
PostPosted: Sun Dec 02, 2012 2:21 pm
Checking caps....
You want the 92-96 wagons. AWD and 2WD are the same, ABS or not, doesn't change the geometry of the part.
LH MB870915 or MB870917
RH MB870916 or MB870918
PostPosted: Sun Dec 02, 2012 3:07 pm
Awesome, thanks.
2018 Hyundai I30N
PostPosted: Mon Dec 31, 2012 4:44 pm
My car now has Expo knuckles on it, and I can safely say the bump-steer has been eliminated. It drives really well now. The 2-piston calipers are a nice upgrade, too. The pedal feels a little mushy initially, but when you really apply some pressure to the pedal, they stop the car nicely.
2018 Hyundai I30N
PostPosted: Tue Jan 01, 2013 1:36 am
:wtg:
PostPosted: Tue Jan 01, 2013 10:40 am
Swapping in a 1" bore MC will help with the soft pedal. One from a na stealth/3000gt or Diamante should drop in.
PostPosted: Fri Mar 15, 2013 5:03 pm
I second that, I have a 92 elantra. I would love to run DSM dual piston brakes on my car.
DD: 98 Park Avenue
Project: 92 (E)Lantra J1 G4CR 1.6L N/A
[Bucket of 4G63 parts from ECMLink to turbo cams, 450cc injectors, GM 3" MAF Sensor, on and on and on...] to pour into it. Keeping the 1.6L though.
PostPosted: Mon Apr 01, 2013 12:33 am
I cut the tie rod mount off,flipped it over and welded it back. Before all the cutting, i made a jig to make sure the tie rods end up in the same place, just upside down......
How's this working out for ya? Any issues? I just hate to see these GVR4 knuckles with brand new bearings sitting here collecting dust. Was hoping they could be modified to work on a friends car.
2012 Explorer Limited
1989 Colt GT clone 4G63t auto
1992 Talon TSi
1990 Talon TSi
1995 Crown Vic
1993 Ford F-250 BBF
1987 Chevy Sprint Turbo
PostPosted: Mon Apr 01, 2013 1:52 am
It's working great. I have been running them for almost a year, and making almost 300whp since late November. I also modified a set for a customer almost 2 years ago and he was still happy with them the last time we spoke. If you want me to mod yours, just pm me. I still have the jig at the shop. Pics are on the first page of my build thread.
viewtopic.php?f=9&t=36123&start=0
