It is currently Thu Oct 23, 2025 11:39 am
 Post subject: CSM intermediate shaft.
PostPosted: Mon Feb 21, 2011 3:07 pm
Does anyone know where a complete axle can be bought for a turbo CSM?
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Mon Feb 21, 2011 11:50 pm
the the intermediate shaft you can also use one from a 1G (and 2G maybe) AWD DSM.
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Tue Feb 22, 2011 8:23 am
I dont want to glue seals together to make it work.
2000 Lexus sc300
2016 ram 1500
PostPosted: Wed Feb 23, 2011 2:17 pm
you dont have to... lol. the stock 1.6T CSM seal works fine.
i thought that two.. also used a DSM FWD F5M33 trans with the 4g61t intermediate shaft as well.. and that worked fine, no axles leaks at all.
PostPosted: Wed Feb 23, 2011 4:41 pm
This is an awd Dsm intermediate shaft in my CSM km-210.
http://i155.photobucket.com/albums/s318 ... 4ec0df.mp4
2000 Lexus sc300
2016 ram 1500
PostPosted: Wed Feb 23, 2011 7:05 pm
I used a 1g dsm intermediate shaft on my 1st colt swap and it leaked like crazy with a fwd axle seal in there. I took a new fwd seal and a new awd seal, used rtv to hold them together and let it cure. I know it sounds ghetto, I thought so too when someone told me to try it. But it worked like a charm and held up fine.
PostPosted: Wed Feb 23, 2011 9:34 pm
Im sending in a few friends to try and get that 4g61 axle from that junkyard this weekend chris. Hopefully they can get it. If not I'll try the two seal thing.
2000 Lexus sc300
2016 ram 1500
PostPosted: Wed Feb 23, 2011 10:27 pm
Yeah that would be the easiest route for sure.
PostPosted: Thu Feb 24, 2011 3:18 am
Couple of questions:
A previous owner installed a long axle (no intermediate shaft) on my Colt and it leaks fluid at the tranny. Is it the seal or is it because of the shaft?
I have acquired the proper intermediate shaft and axle for my Colt, does the intermediate shaft bracket bolt to the block first then the A/C bracket or vise versa?
PostPosted: Thu Feb 24, 2011 6:37 am
If I remember correctly on awd dsm's the ac bracket is used as a spacer for the intermediate shaft bracket.
As for the leak I'm going to guess that the previous owner used a 4g15 driver side "long" axle and that is causing the leak. The 4g15 axle splines are a little too short which causes the c-clip to not lock in to the trans.
2000 Lexus sc300
2016 ram 1500
PostPosted: Sat Feb 26, 2011 2:31 pm
Got a CSM axle today!!!!
2000 Lexus sc300
2016 ram 1500
PostPosted: Tue Mar 01, 2011 2:23 am
Congrats on your find. My long shaft has the same shaft thickness as the correct left short axle, could it be out of a N.A. 1.6 CSM? So would that mean I'm in need of a new tranny seal possibly?
And does anyone else have experience with the intermediate shaft and the A/C bracket as to which one bolts the the block first?
PostPosted: Tue Mar 01, 2011 10:08 am
yes, on DSM's the far left bolt has to go through the a/c bracket... or you can use just a spacer there if you dont have a A/C bracket anymore. its the thickness of about 3 4g63 head bolt washers if im not mistaken. Thats what i used as a "spacer".
On 4g61t with intermediate shaft they use the more right side hole/boss in the lock (closer to the tranny) and the 4g61t intermediate shaft uses TWO spacers on both bolts.... again use a spacer size equivilant to 3 head bolt washers for both bolts.
