It is currently Mon Oct 27, 2025 1:50 am
PostPosted: Thu Feb 03, 2011 7:49 pm
I am looking for the black trim pieces that go vertically near the B pillar of the door. Both of mine are missing or were broken at some point. If anyone has a sedan junker laying around, or a four door parts car, I would love to pick up a set. Again, this is the only vertical piece on the front doors. And the only trim on the upper part of the door.
Steven
1985 Mitsubishi Cordia
Build in progress
PostPosted: Fri Feb 04, 2011 9:08 pm
if you havent found a grille yet, canada4g63 has 3 for sale on this forum. i have been looking for b pillar trim at the yards as well. if i find em ill send em your way.
PostPosted: Fri Feb 04, 2011 9:17 pm
natedog already sent a grill. Should be here any day. Please keep an eye out for a four door. Half tempted to see if a coupe piece will work.
Build in progress
PostPosted: Fri Feb 04, 2011 11:26 pm
The coupe ones are different for sure. I never made it to the other yard on Sunday and it looks like its going to be raining this weekend. If nobody else can get these in the next few days maybe I can grab them by the middle of the week.
PostPosted: Fri Feb 04, 2011 11:32 pm
That's cool. I am not in a big rush, but that is all that is left to complete my missing and broken parts.
I am also using the resource here to see if anyone has or knows of any.
Build in progress
PostPosted: Tue Feb 15, 2011 6:28 pm
Still looking for these pieces. Someone has to have a crappy four door laying around. Or know of one.
Build in progress
PostPosted: Sat Feb 19, 2011 2:17 pm
I just went to a local yard w/ an 89 Summit sedan. I removed the door trims, but the black pins that hold into a clip on the door are broken. But it looks like they are also held on by tape.
If you want, I can wait till Monday or Tuesday to ship that grille out & I can send a set of trim with.
What pieces do you need?
-Shawn
MEMBER #1495
'92 Dodge Colt 63 swap (SOLD)
'92 Galant VR-4 (it's Alive!!)
'12 Forester (DD)
GONE:
'92 Plymouth Colt 12v 4M->5M
'90 Dodge Colt GL 8v 3A
'89 Plymouth Colt 8v 5M
'92 Galant LS
'92 Galant GSR
'93 Galant LS
'93 Galant S
PostPosted: Sat Feb 19, 2011 2:22 pm
They should be bolted from the inside. Unless they are held in like stock I am not interested in the. They can't be broke and have to fasten like stock.
Build in progress
PostPosted: Sat Feb 19, 2011 3:28 pm
There is one bolt location & 1 or 2 alignment pins molded into each piece. Additionally there is double sided tape used.
These pieces look nice, but at least half of the alignment pins have cracked off of the molding.
I know you could attach them w/ the remaining screw & the tape, but thats up to you.
-Shawn
MEMBER #1495
'12 Forester (DD)
GONE:
'92 Galant LS
'92 Galant GSR
'93 Galant LS
'93 Galant S
PostPosted: Sat Feb 19, 2011 3:33 pm
Yeah the pins just position it in the correct spot, the two phillips screws hold it on. I have looked at a few more yards and no sedans so far.
PostPosted: Sat Feb 19, 2011 6:41 pm
Are the screws still there? I thought they were bolts. Haven't looked in a long time. I just need what ever fastens them to be there and not broken. I would likely not reglue them anyway.
Build in progress
PostPosted: Sun Feb 20, 2011 12:19 pm
Sedans are not like the hatches. IIRC, they only have one screw and two pins that are held in by clip.
I have never been able to remove those without breaking the pins and it's not very often that I come accross one in the yard that have those panels intact. Sometimes I see one car may have one that is not broken, but mostly the cars there have all four flopping around because of the broken pins.
3M those, I have pretty much given up in getting a non-broken set for my sedan. :cry: (although next time I see a sedan i'll try once again to remove them without breaking those pins)
PostPosted: Sun Feb 20, 2011 12:21 pm
Well I guess in that case shawn lets make it happen.
Build in progress
PostPosted: Sun Feb 20, 2011 12:40 pm
Will do. Im glad I delayed shipment of the grille. I have to check if they are open today?
If not I will get them tomorrow & send the whole "care package" out to you.
-Shawn
MEMBER #1495
'12 Forester (DD)
GONE:
'92 Galant LS
'92 Galant GSR
'93 Galant LS
'93 Galant S
