I'm trying to get john (crusherbait) to post his set-up his is tits and i can't believe how well it looks and works with no spacer....I hate using spacers the slicks stick out past the wheel well just looks dumb to me...I'm sure he will post up soon and share some of his info he has, took him some doing but he got it right...
what size tire is he running? If I can get away without running spacers that would be great
I would much rather have my tires setup inside the wheel well...
I started off with some GC coilovers w/ 300lbs springs & the Koni sports. Later I added some Weld Draglites 15*8 rims with 4.5†backspacing and M&H 24.5"*8.5". The tires stuck out about a 1.5†I ran that set-up once at the track and found that the tires were hitting the bolt heads that hold up the plastic fender well while making turns. The damage was minor, but still pissed me off a bit.
My new set-up consists of two Centerline one-piece rims that are 15â€*7†with 5.671†backspacing, Hoosier Drag Radial 225/50/15’s and some Hypercoils 500lbs front 450lbs rear.It doesn’t look like summit has any more wheels like the ones I bought on clearance for $150ea.
http://store.summitracing.com/egnsearch ... 4294904624
I’ll post up pics if you’re interested in seeing what they look like.
