It is currently Mon Oct 20, 2025 1:19 pm
PostPosted: Thu Sep 20, 2007 12:10 pm
Not completely finished, but here's the car:
6-bolt 4G63t
SF Header
SF FMIC
Mutiny Custom Cams
FP3575 w/ t3 turbine housing
780s
Walbro 255 HP
DSMLink
MAFT
A whole bunch more...
Car needs to be wet-sanded and buffed (was just painted). I also need to do something about the front bumper (lower lip or something). But anyway, here are a few pics:
-Chris
Chris Mitchell
1993 Mirage Coupe 4G63t
EVT Motorsports
PostPosted: Thu Sep 20, 2007 12:19 pm
:o ... nice mang! like those coupes.
PostPosted: Thu Sep 20, 2007 12:38 pm
6-bolt 4G63t
SF Header
SF FMIC
Mutiny Custom Cams
780s
Walbro 255 HP
DSMLink
MAFT
Whoa, Mutiny Cams? That's a blast from the past!
I've never seen anyone take an FP3575 and put it in a Garrett housing before, that's pretty cool. I really like that turbo in general. You should really consider an intake manifold upgrade in your near future. Very clean car dude.
PostPosted: Thu Sep 20, 2007 1:34 pm
I've been following this on the Mirage Forums as well. Very clean build!
PostPosted: Thu Sep 20, 2007 4:44 pm
Pretty nice looking build man. I think Jerry used some kinda aftermarket Mazda Miata front bumper cover on his car to cover his fairly large FMIC, might wanna ask him about it. What size housing is that, .82?
PostPosted: Thu Sep 20, 2007 9:20 pm
Very nice! If only the MAF Trans and battery weren't there it would be perfect. Usually I hate lots of gauges, but those fit very well in the interior.
How does the radiator/core support on a 4g compare to a 3g? I was thinking of running a Shearer or SLS header on my 3g, and I'm not sure if it will fit (I have the radiator IN the core support now, its an AFCO).
PostPosted: Fri Sep 21, 2007 1:16 pm
Same here...it's just an amazing car!
PostPosted: Fri Sep 21, 2007 2:19 pm
Nice build, when does the 3575 hit full boost?
PostPosted: Fri Sep 21, 2007 2:28 pm
.63 I believe, I'd have to look.
More weight over the front tires!
4500 or so. Hard to tell right now because of my clutch problem; I'll explain it below.
Thanks for all the really positive comments, guys! Unfortunately, the clutch cannot handle the power. I bought a cheap-o Gripforce Ebay 6-puck and it spins at minor boost. I have a 2600lb ACT with street disc on the way. Other than that, the car is a blast. Very nimble even with only aftermarket springs and stock struts. Some nice adjustable struts will make a huge difference. I'll keep everyone post as I get it dialed in with the new clutch and making some real power on the dyno.
-Chris
PostPosted: Fri Sep 21, 2007 3:19 pm
I didn't realize that more weight over the tires meant more traction. :wink:
PostPosted: Fri Sep 21, 2007 11:26 pm
fruit and banana' baller. My dream "DSM". Supposedly the 4g coupes are lighter than the 3g hatches? Anyone know? Either way, it's got that new car feel without the cost of a new car. Complete happy medium!
That t3 housing is uncommon, but I'm down with it. The Mitsu housing is a compromise and doesn't belong in the engine bay at that turbo size IMO.
All it needs is a new steering wheel and that lower IC pipe painted black. :wink:
PostPosted: Sat Sep 22, 2007 12:03 am
Yes, they are lighter. I don't know by how much, but they are.
PostPosted: Sat Sep 22, 2007 8:35 am
according to consumer guide
the hatch weighs 2238 and the 93 coupe weighs 2085
damn think i need to go and buy a 93 coupe
00 lexus gs300
06 buick lucerne
PostPosted: Sat Sep 22, 2007 10:56 am
That is exactly why I chose this car. Feels a bit newer on the interior, SUPER light, and unique. They car feels like a toy weighing what it does. Bad news, though. ACT Clutches are on backorder for my car, so I am stuck with this shitty Ebay clutch for a while.
-Chris
PostPosted: Sat Sep 22, 2007 11:08 am
-Chris
Where are you trying to order your clutch from?
www.roadraceengineering.com has some great deals on ACT clutches. I'd highly recommend the 2900lb kit for your setup though. The 2900lb plate actually has a lighter pedal feel than the 2600lb due to a different pivot point on the fingers of the pressure plate.
