It is currently Tue Oct 21, 2025 6:49 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 178 posts ]  Go to page Previous 1 2 3 4 5 612 Next
PostPosted: Thu Mar 08, 2007 9:56 am
Is that the right shifter arm on there? Looks like a dsm one
PostPosted: Thu Mar 08, 2007 10:28 am
YEP i HAVENT "MODIFIED" IT YET
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Sun Mar 11, 2007 10:05 am
since you have no interior anywys why dont you just leave the shift arms on there and run dsm shifter cables and a dsm shifter assembly in the car? Then you could buy readily available short shifters. I never understood why nobody does this.
PostPosted: Sun Mar 11, 2007 11:43 am
Hmm I've never thought aabout it that way I do have a DSM shifter and cables I'll take a look at it, thanks.
Adam
05'WRX
PostPosted: Sun Mar 11, 2007 7:33 pm
yeah, no problem, that is what i plan on doing, it just seems a lot more simple then changing the arms on the tranny. Im pretty sure the dsm shifter assembly will even bolt in but im gonna weld mine in with 2-3" spacers under it to raise the shifter up closer to the steering wheel.
PostPosted: Tue Mar 13, 2007 12:43 am
I ended up just cutting and re-welding my shifter arm. They are a b!tch to remove imo.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Tue Mar 13, 2007 9:47 am
Drop the Summit off tomarrow at HTP, I feel it will be done to my professional standards.
http://www.hitunedperformance.com/
not really a website just a pic
PostPosted: Tue Mar 13, 2007 10:52 am
Looking foward to seeing the work they do, I have heard they do really good work. I have only been up there myself a few times and didn't get to see much dsm stuff, but I did see the rb26 swapped 240sx in progress.
PostPosted: Tue Mar 20, 2007 10:25 am
I removed 3 pages worth of random post so were down to 4 good pages of good info.
Adam
05'WRX
PostPosted: Fri Mar 23, 2007 11:54 pm
here are the 91' DSM spindals thats are going on it. I blasted it all then a fres coat of paint, I should of taken some before pictures. All i can say is they came from a junkyard. I filled the clean bearings with synthetic grease.
PostPosted: Sun Apr 08, 2007 9:36 pm
Brakes are all togeather fronts and rears. I used synthetic grease through-out. I like the red caliper paint. :D
PostPosted: Mon Apr 09, 2007 10:36 pm
thats why i made a tool to remove the shift arm pin with the tranny still in the car...
PostPosted: Tue Apr 10, 2007 11:32 am
So you'll be posting pics of this tool how soon? :D
1999 Ford Contour SVT
PostPosted: Tue Apr 10, 2007 4:44 pm
Man that Red is so bright !
Lancer C68 4G67t
Eclipse D22 4G63 Cyclone
Eclipse D27 E316g,too much to List here.
Galant EA0 V6-24V
PostPosted: Wed Apr 11, 2007 7:22 pm
soon, i found after i picked up 3 stitches in my left thumb after smashing it with a 5 pound sledge i needed something a tad better.
