It is currently Sun Oct 26, 2025 1:43 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
PostPosted: Thu Dec 25, 2008 3:30 pm
I'm looking to throw a half inch spacer on each side and give them a shot... the car is a street car and would like to have it rub as seldom as possible, but with a car making alot of traction I would like it to have as much meat on them as possible...
who has run the 235/60/15 ET streets?
how did you like them/ how did they hook?
how bad did they rub?
how long did they last for?
thanks in advance
Andrew.
PostPosted: Thu Dec 25, 2008 6:01 pm
1595 cc's of fury
Thats a huge tire for our cars....you would need coil overs to even have a chance of fitting.
PostPosted: Thu Dec 25, 2008 9:36 pm
well I picked up a set of 24.5 by 8.5 by 15 inch mickey thompson et drags tonight for dirt cheap :)
PostPosted: Thu Dec 25, 2008 10:09 pm
Better find some coilovers to go with them...
PostPosted: Thu Dec 25, 2008 10:25 pm
sounds good, I'm going to space them out about a 1/2 an inch and see if they clear, if not Coil overs here I come.
Andrew.
PostPosted: Thu Dec 25, 2008 10:30 pm
Ebay sells some cheap coilovers that work great on the colt...
PostPosted: Thu Dec 25, 2008 11:42 pm
under what car? can you post a link
PostPosted: Fri Dec 26, 2008 3:28 pm
please do :)
Andrew
PostPosted: Fri Dec 26, 2008 11:29 pm
We run a 26" M&H bias ply drag radial on the street without problem, just needs some spacers. The car does have coilovers, but it wasn't because the tires were too tall.
PostPosted: Sat Dec 27, 2008 11:16 am
m
how wide were the tires, and what size were the spacers!!!
PostPosted: Sat Dec 27, 2008 3:24 pm
I'm trying to get john (crusherbait) to post his set-up his is tits and i can't believe how well it looks and works with no spacer....I hate using spacers the slicks stick out past the wheel well just looks dumb to me...I'm sure he will post up soon and share some of his info he has, took him some doing but he got it right...
PostPosted: Sat Dec 27, 2008 4:37 pm
what size tire is he running? If I can get away without running spacers that would be great :) I would much rather have my tires setup inside the wheel well...
PostPosted: Sun Dec 28, 2008 11:08 am
I started off with some GC coilovers w/ 300lbs springs & the Koni sports. Later I added some Weld Draglites 15*8 rims with 4.5” backspacing and M&H 24.5"*8.5". The tires stuck out about a 1.5” I ran that set-up once at the track and found that the tires were hitting the bolt heads that hold up the plastic fender well while making turns. The damage was minor, but still pissed me off a bit.
My new set-up consists of two Centerline one-piece rims that are 15”*7” with 5.671” backspacing, Hoosier Drag Radial 225/50/15’s and some Hypercoils 500lbs front 450lbs rear.It doesn’t look like summit has any more wheels like the ones I bought on clearance for $150ea.
http://store.summitracing.com/egnsearch ... 4294904624
I’ll post up pics if you’re interested in seeing what they look like.
PostPosted: Sun Dec 28, 2008 12:15 pm
pics please...
PostPosted: Sun Dec 28, 2008 12:17 pm
please do, and if at all possible what do you guys recommend for spring rates for drag use?
