It is currently Fri Oct 24, 2025 9:25 pm
PostPosted: Sun Oct 03, 2010 12:06 pm
So after a while of thinking and a little work, my brother and I have came up with another option for the brake upgrade. I could have easily used GVR4 hubs, but I opted to go this route instead of throwing off the camber and such.
First we pressed apart the stock hub assembly, and unbolted the captive rotor. Then he used a lathe to turn down the hub enough for a GVR4 rotor to slide over from the front. This is the assembly on the car. (I installed new DSM lug studs, they looked a couple threads longer than the stockers).
Slide the GVR4 rotor over the hub, and then you can install the twin piston caliper. Using a 5.5 mm spacer between the caliper and hub assembly, will set the caliper where it needs to be. I'm having the spacers made, but for now 2 washers I picked up measure in at 5mm (should suffice for mock up). I'm also going to shop around for 5 mm longer bolts.
I'm sorry for the crappy cell phone pictures, but I figured this might interest some of you... Questions? Thoughts?
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Oct 03, 2010 3:37 pm
That seems pretty cool. It would help eliminate the camber and bump steer issues. Only hard part is the lathe on the hub. But if you go at it with a grinder it will take forever and be out of balance.
Good work!
PostPosted: Sun Oct 03, 2010 7:28 pm
viewtopic.php?f=10&t=24309
Looks like I'm re-inventing the wheel :)
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Oct 03, 2010 7:52 pm
CSM Dik
I've been wanting to do that to my hubs but I wasn't sure if I could use the twin-piston calipers or not. For some reason I was under the impression that they still wouldn't fit right,and that Expo or GVR4 knuckles were needed. Sweetness :D
Dale
PostPosted: Sun Oct 03, 2010 8:54 pm
This looks like a viable option. I have the whole knuckle and everything. I have it, the hubs, and both calipers for anyone who might be looking! Thanks for the info! If they don't sell I know what I'm doing!
PostPosted: Sat Oct 23, 2010 2:23 pm
Any idea if a gvr4 or expo hub would just press into the colt wheel bearings? Then maybe machining and spacers wouldn't necessary?
PostPosted: Sat Oct 23, 2010 4:15 pm
They don't, the csm wheel bearings and hubs are completely different.
PostPosted: Tue Oct 26, 2010 7:36 am
and 1/4" plate works for spacers too, might be easier to work with...
PostPosted: Tue Oct 26, 2010 9:38 am
I ended up going with 5.75 mm spacer, which is right at 1/4 inch. I ordered 5 mm longer bolts from Fastenal (grade 10.9) so I'd feel safe about the set up. It's all installed now with SS brake lines from a fwd DSM. The were a bit shorter than stocks, but don't bind, even lock to lock. I'm waiting on my rear drilled rotors to get in before I try the back lines. :D
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sat Nov 06, 2010 10:04 am
CSM Dik
What's the minimum wheel size when going to the bigger calipers,15's?
Dale
PostPosted: Sat Nov 06, 2010 10:44 am
Yes, 15's seems to be the smallest you can run.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sat Nov 06, 2010 10:47 am
Stock turbo 266mm brake rotors and their calipers just, and I mean just, clear the stock 14" rims.
Users browsing this forum: No registered users and 62 guests
