It is currently Sun Oct 26, 2025 5:00 pm
 Post subject: HORN........
PostPosted: Sat Jun 12, 2004 12:23 am
Hey All,
This Little buzizng Horn in New York City is starting to pioss me off on this small hatchback. Did anyone install a louder horn? I want to do this, and I think all i need to do is install a new one, and rewire it to the old horn so they both beep.correct? Let me know how this can be done, and if anyone played with this. Thanks..
http://www.angelfire.com/oz/plymouthcolt/index.htm
1990 Plymouth Colt GL
4g15
_______________________
Szymon Zmijewski
Sierrazulu85@Aol.com
 Post subject: ez man
PostPosted: Sat Jun 12, 2004 12:43 am
just use the positive from the existing horn for a signal to the new horn. a signal two grounds and a constant for the relay and ur set man
4G63T Powered C10 In the workin
Injectors wont work
PostPosted: Sat Jun 12, 2004 12:49 am
what do you mean a constant for the relay? I attach one wire to the posastive of old horn, and the other wire on the new horn, to the frame of car, and that's it right? Let me know.thanks!
4g15
Szymon Zmijewski
PostPosted: Sat Jun 12, 2004 2:09 pm
He's talking about a high-current cruise ship horn, I think.
Yes, you should be able to get a better one and wire it straight in.
Witty Signature Goes Here!
 Post subject: yup
PostPosted: Sat Jun 12, 2004 2:23 pm
im talking about a boat horn. if you want loud thats the only way to go. you need a relay. it gets the positive signal from the old horn. the ground is supplied to the rely and the new horn. the other post on the rely is constant positive and the last post goes to the new horn.
Injectors wont work
PostPosted: Sat Jun 12, 2004 5:05 pm
dodge neon horn is loud. i had it on my last mirage, it lets people know im comming. you can probly get one at a junkers for less than 5 bucksits more of a horn design then a door buzzer design.
4g61t.com
PostPosted: Sun Jun 13, 2004 9:02 pm
Just get a set of air horns. You can find them at Shucks etc. for about $20. Typically they come with a relay. I've got a set on my Colt. I think every vehicle should have 'em.
Trent
'89 Colt GT
Member #1
