It is currently Sun Oct 19, 2025 10:41 pm
PostPosted: Mon Dec 08, 2003 11:47 pm
Hey guys, I have a race motor in my 91 eclipse, with 92 ecu, I have this 89 turbo shell, I can get a 90 harnes for cheap, but then ill have to get all the crap with it such as throtle body, cas, transistor, coil pack all the sensors, the ecu i can use , only 2 pins have to be changed for 90 harnes, my question is.... can I use a 91 harness, if so what do I have to change, I can also get that one cheap, please let me know
thanks alot guys
PostPosted: Mon Dec 08, 2003 11:55 pm
IMO get a wiring harness that matches the ECU and setup already on the motor. 91+ harness would be better. hope that helps
94 Mirage Project underway...
PostPosted: Tue Dec 09, 2003 12:03 am
Im not worried about my ecu, im worried about what harnes i can use on the 89 turbo mirage, if it matters, if my motor is 91, and i can get a 91 harnes and the 92 ecu is compatible, why get a 90 harness? am i right or am i wrong, If I get a 90 harness , id have to get alot more stuff, but I Dont see why I cant use the 91 harness, I think ill get that, im still askin to be 100% sure hehe
PostPosted: Tue Dec 09, 2003 12:09 am
if you can get a 91 harness use the 91 harness. if my memory serves me right the only major difference if coil pack and transistor box. some please feel free to correct me if i am wrong
PostPosted: Tue Dec 09, 2003 12:11 am
My 91 engine has evrything from 91 , brand new 91 transistor,coil pack, TB+ sensors,cas all that stuff, all id need is the 91 harness then... hmm alot easier then getin a 90 harness wich isnt too compatible with the 91-94, 90s are almost extict hard to find crap for.
PostPosted: Tue Dec 09, 2003 12:43 am
so the 91 harness will work in my 89 turbo shell ?
anyone ?
PostPosted: Tue Dec 09, 2003 3:40 pm
The CSM 4G6x/4G61T harness is the same as the 90 DSM harness. Sure a 91+ harness will work. But why mess around w/ a +91 harness when swapping 2 wires and the ignition stuff is enough?
Or did I misunderstand you?
Got rabies?
PostPosted: Tue Dec 09, 2003 4:11 pm
because this turbo shell has no harnes no ecu, i have a 91ecu/motor and can get a 91 harness, hehe dig me ? no point of getin a 90 harnes because ill make more work for me to get all that other crap such as a 90 tb, coil pack and on....since i have evryhintg from 91, so if i get the 91 harnes it will plug in into the 89 turbo shell... thats all i have to know
PostPosted: Tue Dec 09, 2003 5:01 pm
In your original post you said you had an 89 shell.
Having "just a shell" can mean different things to different people.
A shell can contain a harness... got me? try to be more specific so we dont bog the thread down with info that doesnt pertain to your situation
I HAVE a 91 turbo harness... 100 bucks and it's yours...
I take paypal.
G-
Geoff
89 Colt Turbo
92 GVR4 254/1000 Kensington Gray
PostPosted: Tue Dec 09, 2003 6:30 pm
sorry its a shell without th harmess, i can get a 91 harnes for alot cheaper,unless youl take 65$ offer ill take it, my question was will it plug in thats all
PostPosted: Tue Dec 09, 2003 6:57 pm
It will plug in, your tach won't work....
PostPosted: Tue Dec 09, 2003 6:58 pm
what if i got the stock turbo mirage wiring harness, can I use the 91 engine sensors and all that or no, for the tach thing, has to be some kinda fix on that hmm
PostPosted: Tue Dec 09, 2003 6:59 pm
why wouldnt the tach work with a 91 ECU 91 Wiring harness and 91 Coil pack and transistor pack?
PostPosted: Tue Dec 09, 2003 7:03 pm
yea thats what im sayin, i dont see why it woulndt work if im using evrything else from a 91 heh
PostPosted: Tue Dec 09, 2003 7:42 pm
Check this post.
http://www.4g61t.com/forum/viewtopic.ph ... ness#37217
