It is currently Sat Oct 25, 2025 11:53 pm
PostPosted: Sat Nov 08, 2003 2:08 am
I am sooo sick of my front disk breaks squealing! I have paid brake masters over 1500 in the last year to fix this problem and it comes back after a month. Im soo tired of it! When the rotors get warmed up after a few stop lights they get VERY loud, so loud i have people blocks down the street looking at my car. I just plain sick of this! I am thinking of getting 1000 grit sandpaper and just rubbing the hell out of the rotors to take off any glaze. Will this work?
You may be thinking 1500! holy cow! and yes its true, and everytime brake masters resurfaces the rotors and gives me new brake pads and this lasts at MOST for 2 months. I want to go burn down the place and get that 1500 back. BTW I have the unlimited brake pad thing and it hasnt been usefull.
PostPosted: Sat Nov 08, 2003 2:18 am
BANNED FOR FRAUD
Get some quality pads for one. That lifetime crap is just that. Try some performance carbon metallic ones, and maybe talking off the dust covers.
Jason Veraldi
Scammer
PostPosted: Sat Nov 08, 2003 3:30 am
Simple fix. My Talon had the same problem until I installed some anti-squeal shims. Problem went away immediately and has never come back.
I think the shim kit (includes the compound to mate the shims to the pads) was something like $35.00 US. Took about 30 mins for each side.
Maybe an option?
-Kev
Cheap, Fast, Reliable......you can only pick <b>TWO</b>.
PostPosted: Sat Nov 08, 2003 10:34 am
definetly pull the brakes apart and make sure the anti-squeal shims are in, use the anti-squeal glue stuff and glue em to the pad and to the caliper as well. thats how I always glue em and ive never had squeal
RIP- '92 Colt 200E, 12valve 4G15, 5spd.
'89 Colt 200E, stock 8valve 4G15, 5spd,
PostPosted: Sat Nov 08, 2003 10:47 am
BANNED FOR FRAUD
Oh yeah, that too. I always forget about that stuff. :wink: You can't go wrong with some better pads too. Our cars need alot of help in the stopping dept.
Jason Veraldi
Scammer
PostPosted: Sat Nov 08, 2003 11:18 am
ohh ok thanks guys! i thought the sqeal was from the rotors vibrating so i was just going to sand the hell out of them
PostPosted: Sat Nov 08, 2003 12:27 pm
If all else fails I could send you an entire hub/knuckle assembly with the rotor and caliper with pads, that came off a car that was driven in by a customer.
I would also recomend going with the Nippondenso ceramic pads, they have the anti squeel pads already glued to the backing and those pads last along time with little brake dust.
You could even go with a set of sloted or drilled turbo rotors, and calipers
If it don't make power it's not worth the hour!!!!!
PostPosted: Sat Nov 08, 2003 12:36 pm
FYI: Mitsu anti-squeel shims for CSM, DSM, Galant, Space Runner, Space Wagon:
Part number X3511102 SHIM KIT, FR BRAKE
Got rabies?
