It is currently Sat Oct 25, 2025 4:06 pm
PostPosted: Fri Nov 07, 2003 6:55 pm
im rplacing both and cant get my hands on a manual so a little guidance would be helpful
thanks in advance
PostPosted: Fri Nov 07, 2003 8:04 pm
This info is regarding 8v version - 12v may be different.
O2 sensor is threaded into the lower part of the exhaust manifold. Some newer cars might have an additional one near the cat. Be sure to saturate it w/penetrating oil(PB blaster,wd40,etc) before attacking it.
On my 8v 4G15, the temp sensor is threaded into the intake manifold near the t-stat cover.
Torque recomendations for O2 sensor is 33ft lbs and for the coolant sensor 19ft lbs.
91 Hyundai Excel GS - stepbrother to the CSM
88 Piazza Turbo - Italian-Japanese fusion
88 Isuzu Trooper - 4x4 fun!
PostPosted: Fri Nov 07, 2003 11:18 pm
Be advised that the O2 sensor can be extremely difficult to remove!
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
