It is currently Sun Oct 19, 2025 8:01 pm
 Post subject: WTB: 90 amps alternator
PostPosted: Fri Aug 03, 2018 2:02 am
anyone has the galant or 2G 90 amps alternator?? is this a bolt on alternator to our csm?
PostPosted: Sun Aug 05, 2018 9:07 am
Galant VR4 90 amp alternator is a direct bolt on, 2G I would research if people use that in either alternator location or not. Most people are sourcing the GM alternators and having to do some case and or block grinding for clearance. Might be the best option for rock steady voltage at idle and on up to redline. I run the 90 amp alternator and it does fine, with two aftermarket fans and upgraded wiring in every position.
PostPosted: Tue Aug 14, 2018 9:09 am
anyone using 90amps alternator?
