It is currently Tue Sep 16, 2025 5:42 am
Post new topic  Reply to topic  [ 206 posts ]  Go to page Previous 110 11 12 13 14
PostPosted: Fri Jan 05, 2018 9:29 am
Any chance you could reupload pics of that key fob remote? Might try to get mine working too and really don't know which one I'm looking for. I found some older 2 buttons on eBay but would like to make sure before I buy.
PostPosted: Tue Jul 03, 2018 1:10 pm
updating my thread here to motivate myself. pulled the car into work space to get some stuff done . progress stopped when I discovered the ECU relay was wired wrong. it did not provide five second delay at shutdown. the ECU needs this delay to be able to tune. changes to tune are lost at shut down without it. no one could tell me where this delay comes from. so it became this intimidating wiring nightmare to diagnose and correct. hating to work on wiring problems I pushed car to side. then as car sat I became over whelmed with all the things this car needs to be considered close to finished. time to make some progress.
1. correct ecu wiring
2. wire-in boost activated blue wire mod
2.5 install Defi advance ZD, additional sensors to monitor trans temp, pressures and IC temps.
3. install primary fuel system. evo X injectors and pump
3.5 convert to speed density and tune drivabilty
4. remove trans to fix LSD whine.
5. install secondary fuel system tune for power.
6. finish modifying fr bumper. paint.
7. epoxy foam fill chassis.
8. rebuild rear suspension.
9. upgrade brakes
10. convert rear LSD setup.
11. finalize exhaust setup (remedy 3500rpm drone)
12. modify suspension for better handling.
12.5 led custom headlight build
13. enjoy the xxxx out of driving the car.
got number 1. done on sunday. took about 4 hours to figure it out. will be updating regularly again. super excited to be back on this project. will be updating pics as I get the time. postimage changed server or something and every pic has a new ID that will need to be updated one by one. I also want to get all pics out of photbuckethell and into postimage. hopefully they dont go down same road. in the meantime here is link to gallery https://postimg.cc/gallery/2kxgcnej8/
PostPosted: Tue Jul 03, 2018 11:28 pm
nice at least u are motivated some now.. i walk past mine 5-8 times a day to take the dog out and by time I get back inside im like ohhh this feels good and cool in here then I sit down and blah lol..
what front bumper is that?
PostPosted: Fri Dec 21, 2018 7:57 am
hey guys. do you guys see my photobucket pics on page one?
PostPosted: Fri Dec 21, 2018 12:49 pm
I do.. with a big thing saying proudly hosted my photobucket on the lower left side...
PostPosted: Fri Dec 21, 2018 6:19 pm
Yes, they work.
PostPosted: Mon Aug 24, 2020 2:41 am
Hey Lancerman! Did you fall off the motivation wagon again or are have you made a huge dent in your list of things to do?
PostPosted: Thu Aug 12, 2021 5:18 pm
just checking in. my summit has been my daily driver for a couple years now I havent done anything to make it fast. all the defi gauges are in and working. the exhaust drone fixed itself and sounds amazing as long as the window is up. I get a lot of people not really liking the side pipe exhaust. and I finished mounting front bumper side filler strips. I dont have any drive to drive fast anymore. kinda wish it had a smaller turbo on it but I have gotten used to it. for a while was running around with no clamp on the intake tube but the a/f was like 19.5 and it was getting amazing gas mileage like that in chill mode. the car drives amazing and my wife loves to drive it too. its basically on stock ecu and 450s and have managed to drive it like that without hurting it. plan to make a short video of the car so people can see how clean this car is.
PostPosted: Thu Apr 07, 2022 6:27 pm
Would love to see pics. Hoping it isn’t still broken in the site.
Try uploading one and see if people can see it before adding everything. I think the site is still broken even with the updates and pending issues and using an old version of phpbb that the host will be having issues with.
PostPosted: Tue Jan 30, 2024 1:05 am
DAMN this build is so informative, you killed it @lancerman, just got a 94 rvr imported and gonna do some of these mods as the thing is like 2ft off the ground
PostPosted: Tue Feb 13, 2024 1:11 pm
LM,
Keep doing the 'Good (Great) Work'!
Subscribed!
:popcorn:
Best Skill (& Luck),
