It is currently Sun Oct 19, 2025 6:48 am
 Post subject: ECU's
PostPosted: Sun Oct 01, 2017 4:12 am
So, I just picked up an ECU from the wreckers as an extra just in case. My current cars are 92 and a 93 Vista's and the ECU I picked up is from a 94.
I didn't even think about it but when I got home I realized that the 94 ECU is EEPROM. What kind of benefits can I gain by socketing the ECU? (i.e. Would it be worth it?)
 Post subject: Re: ECU's
PostPosted: Tue Oct 03, 2017 11:34 am
Sorry I can't answer your question about your new eprom but have you checked to see if there are any differences between the 92 and the 93+? The reason I ask is because the 92 has an 8v 6 bolt engine which is different from the later models. If they are indeed different you'd need a spare for your 92 as well.
PostPosted: Sat Oct 07, 2017 1:31 am
Well, I'll do some more digging but I also have a 93 and I know the 94 ECU will interchange into that.
