It is currently Mon Jun 03, 2024 11:25 pm
 Post subject: Starter wiring
PostPosted: Sun Oct 09, 2016 12:58 am
I removed the starter and forgot how the wiring goes... Anybody know how to wire the harness and the wires on the starter itself?
 Post subject: Re: Starter wiring
PostPosted: Mon Oct 10, 2016 9:25 am
Large positive wire from the main lug terminal (copper plated stud) to the battery positive terminal.
Ground wire from one of the 2 long bolts for the starter at the bell housing connection point, direct to chassis ground at the bolt location just below the factory battery location.
The bolt used to ground the wire at the chassis should have no plating, and should have little depressions in the threads that self clean/tap the hole as it goes into the threads. Special bolts from all the rest. I have one that is labelled "E" on the head, for earthing type bolt. Not sure if it is original to the turbo or if I grabbed ti from the 1992 Colt, or some other car along the way. Technically, any car that uses a ground wire setup this way, is a source for a new bolt to use.
Solenoid feed comes from the starter ignition switch and is usually a black wire/yellow solid tracer to the single push pin connection on the bendix.
http://www.lilevo.com/mirage/89%20Colt% ... 0TURBO.pdf
Page 82/328 or 8-56 if the PDF page reference is off for some reason.
PostPosted: Mon Oct 10, 2016 9:26 am
This will also come in handy - ECU pinout/fanout sheet:
http://www.lilevo.com/mirage/ECU%20edit ... mplete.jpg
PostPosted: Tue Oct 11, 2016 6:09 am
Got the starter wired up... What am I looking at here? The red lines are a modification to the harness?
PostPosted: Tue Oct 11, 2016 6:23 am
Any colors associated with the interior, may be somewhat different from the exterior/engine bay. They can change colors only once they get to a connector of some sort or a fuse block.
