It is currently Tue Oct 21, 2025 12:55 am
Post new topic  Reply to topic  [ 167 posts ]  Go to page Previous 18 9 10 11 12
PostPosted: Sat Jan 09, 2016 9:24 am
Carried over from the AWD Tech. Applies the same.
For Reference. measurement Info from RockAuto as of Jan 2016 these items are still available.
Keep in mind that if you use DSM axles with DSM/Expo/Gvr4 knuckles you must use DSM or GVR4 Wheel seals
If you use CSM Turbo axles with DSM/Expo/GVR4 knuckles you must use seal #225082
If you use CSM Turbo axles with your CSM knuckles reuse your original wheel seals.
If you use DSM axles with your original CSM knuckles I have no clue......
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Mon May 30, 2016 11:33 pm
803019 for $72 shipped
http://www.amazon.com/Empi-80-3019-Join ... B000JZH0G8
MI-8133 for $58 shipped
http://www.amazon.com/SurTrack-MI-8133- ... ds=mi-8133
