It is currently Sun Oct 19, 2025 4:52 pm
PostPosted: Wed Sep 23, 2015 12:04 pm
1989 4g63 AWD Mirage
First in case anyone is delusional this is NOT A DD in any sense of the word.
It has NO heater, no windshield wipers, no blinkers heck not even a dash.
There are working lights and brake lights.
This car was built for one purpose and that was to be FAST.
When I bough it the car was pretty much stripped I just went a little further.
Here are the mods. I might be forgetting things.
Brandon
303-710-1432
2300 lbs with 5 gallons of gas in it
666 hp at 38ish psi.
Shell:
Clean Colorado title
Original turbo model
2.0 swapped
Awd swapped using 1g parts.
NO SPEEDO or ODOMETER!!
NO windshield wipers
No blinkers… but you could make them work.
NO KEY. Push button start
Motor:
1g 6 bolt 2.0
Eagle crank
Eagle rods
Wiseco HD 9:1 pistons
Acl race bearings
20 over
Head:
2g ported and polished by headz by drew
1mm over size valves
Kiggly hla
Kiggly springs and retainers
Kelford 272s
Steering Suspension:
GAB rear coil overs
1g dsm front struts with stock height springs
Non power steering model
Forced induction:
Pte 6466 t3
T3 punishment racing budget manifold
3 inch dp back with inline magnaflow(I think) muffler
Ets 1g fmic 2.5 cold side and 3 inch hot side piping
Gm maf
Tial 2 bolt 38mm wastegate
Dumps out of a hole in the hood
Electronics:
1g v3 full dsmlink
5 bar AEM map sensor
5 inch tach/shift light
Coolant temp gauge
AEM wideband
Fuel:
5 gallon fuel cell
Dual bosch 044s
-8 feed and return
FPR
1600 cc injectors
Transmission:
1g built trans with 4 spider center.
This is honestly one of the best shifting trans I have ever had.
Cooling:
Ford ranger 4.0 monster radiator. Installed in the frame support
Big rad fan. I can’t remember the name..
Fan controlled by a relay through link. Fully adjustable
Others:
4 bolt rear end
Lsd rear diff
Custom driveshaft done locally
Harness bar bolted in for easy removal for a cage
Front lower rad support was cut out and a large bar was welded in. Front motor mount bolts to it
A rear motor mount was also welded to the car.
Both are removable which makes for easy removal of the engine.
Rear of the car was removed for install of the rear subframe
It was then covered with tin and a 1.4 inch this piece of aluminum.
This car is loud and obnoxious!!
It’s a noisy ride and stiff because of the rear coilovers.
This is a purpose built car. Put a cage in it and you will have an absolute monster!!
Body is pretty straight.
No front bumper.
The hood was gutted which makes the hood WAY to flimsy. It will need replaced or reinforced. I didn’t know how thin the metal was when I did this.
I have tried to be as honest as possible. If I remember more I will add it.
A similar setup with motor issues, heavier and most of the interior sold for 7100 recently.
I have no idea how to price this so I will put the price at 12k.
This is not a firm price just a starting point.
Brandon
303-710-1432
Money talks BS walks. Don’t think you will get this car for a few thousand bucks.
1985 Mitsubishi Cordia
Build in progress
PostPosted: Wed Sep 23, 2015 12:47 pm
I cannot attach pictures from my phone and don't want to deal with uploading all of them. If you needs pictures please text Brandon or myself. My number is 720-483-9375
Build in progress
PostPosted: Wed Sep 23, 2015 9:05 pm
I bet this thing is a blast to drive, but he might as well keep it. Realistically he will be lucky if he gets half his asking price. Parting it out will get him more of his money back.
PostPosted: Thu Sep 24, 2015 6:20 am
He will sit on it until he gets a good price. This one will not be parted.
Build in progress
PostPosted: Sun Sep 27, 2015 11:37 am
12k...? Where do you guys get your numbers out there? Really, every car I've seen you post for sale has retard high prices, I don't get it. If this was the cleanest mirage out there and professionally built, I still don't think it could get 12k. But hell, its not my car, not my price. Glws
PostPosted: Sun Sep 27, 2015 3:15 pm
I agree that $12k sounds high, but you couldn't build this thing for cheaper than that, even if you do all of your own work. I've seen the car in person, and it's very nice.
PostPosted: Sun Sep 27, 2015 6:20 pm
Not my car, not my price. And what cars have I listed high? I am the most realistic person out there.
Build in progress
PostPosted: Mon Sep 28, 2015 7:59 pm
Unless your anyone from Cleveland. JP/Craig built both there outta cheap but proven combos. I do believe this car is a little over price seeing how the black one on here sold for around 7500ish. But everyone has the right to sell there car for the price they believe it is worth, and the harsh reality is we never get back what we put into our cars.
PostPosted: Mon Sep 28, 2015 8:10 pm
Not to take a stab at George for quality of his car, but I can definitely say that the AWD conversion and suspension work on this car is MUCH better. The black car looked much prettier, but this is a down and dirty race car, and it's not pretending to be anything else.
PostPosted: Mon Sep 28, 2015 8:32 pm
Here are some pics I took of the car while I was in the area. Keep in mind that it's no cream puff. You're basically getting a kick-ass powertrain and drivetrain with a 25 year-old, original Mirage body slapped on top of it
PostPosted: Thu Oct 01, 2015 11:12 am
The car has now run a 10.4@142
https://www.youtube.com/watch?v=ag0v7zi ... pp=desktop
Build in progress
PostPosted: Fri Oct 02, 2015 8:21 am
Love it!!!!! :heart:
