It is currently Sun Oct 19, 2025 12:24 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
 Post subject: Re: Van rear disc brakes
PostPosted: Mon Sep 01, 2014 7:11 pm
Please for the love of god, make sure that the rear diff ratio is exactly the same as what the front comes with. If the original rear diff is re-used, no issue, but like JDM Galants, diffs changed many ratios, don't want you to find out the hard way.
PostPosted: Mon Sep 01, 2014 10:13 pm
For anyone else looking my old 94 summit wagon with abs and rear discs is still at the local JY where the new owner wrecked it. I'd be happy to pull this stuff for someone before they scrap it.
PostPosted: Mon Sep 01, 2014 10:34 pm
no woorys im going to use 1g 3 bolt lsd in the back as I was under the impression that the half car came with a lsd but it didn't so no matter what I have to make a custom axle
PostPosted: Wed Sep 03, 2014 4:40 pm
I might be interested! I hate drums on my van :). How much would they want for them?
PostPosted: Wed Sep 03, 2014 9:12 pm
I forgot to mention that this wagon in particular is FWD. As long as the AWD wagons with rear drums use the same hubs as the ones that came with rear discs everything else should swap over. I'd need to grab the calipers, backing plates and all hardware. Not sure about the e-brake cables. Would be better to go with new rotors and pads.
PostPosted: Thu Sep 04, 2014 1:21 pm
I think that we went through this already when it was first totalled :). I am 95% sure that FWD backing plates are different from AWD backing plates :(.
PostPosted: Thu Sep 04, 2014 2:39 pm
I remember pulling a rear disc setup for another member on here from an awd summit. Everything but the rear hubs look exactly the same but I've never had both side by side for comparison. I no longer have CAPS on my computer to verify part #'s though.
PostPosted: Tue Sep 30, 2014 7:48 pm
if its still there see how much your 5 speed swap stuff would be, also shipped to 98661
