Ok so to start off, i am working on my 1990 Mitsubishi mirage 4g15
To start off, i have already swapped in a 5spd manual transmission from a 1989 dodge colt 4g15. I converted it to hydro clutch and all the linkage is working well.
My issue is with the electrical system. when i try to start the car, I blow fuse #5 (10A) which controls the Back-Up Lights, Hazard Warning Lights, Inhibitor Switch (A/T), 3-Speed A/T Control Unit.
http://www.lilevo.com/mirage/89-92%20Co ... eakers.pdf
Simply put, the car wont start.
I read on the forum that i need to jump Pins 8 and 9 together to bypass the clutch. I tried that with no result accept popped fuses. Pin 8 and 9 are on the connector going to the old automatic transmission right?
What would keep blowing the fuse, and perhaps, is that whats keeping my car from starting?
thank you
this site ROCKS!
also can i completely remove the TCM computer?
