It is currently Mon Oct 20, 2025 1:36 am
PostPosted: Wed May 28, 2014 7:52 pm
The C53A proportioning valve is what you want if you have a sedan converted to rear disc brakes, a sedan AWD swap, or even a FWD sedan 4G63 swap.
The rear bias is very weak on a rear drum sedan.
Some relevant information courtesy of ColtiXim:
"The proportioning valve from the C66 Lancer need to be swaped from a all wheel brake disc !
We have found 42% ( Limit autorized in Europe 50% ) efficiency on the rear axle with the stock C66 valve ( drum brake ).
And 60% efficiency with a C53 valve :wink:
For reference :
LANCER GLXI C66 4G92 Motor
proportioning valve ( drum brake ):
MB316182 or MB699642
European C53A GTI 4G61N/A Motor
proportioning valve :
MB316181 or MB699641
USA C53A 4G61T Motor
MB316180 or MB699640
Brake booster:
MB668505
All type C53A
Brake booster:
MB618442 or same as Lancer C66 MB668505
Same 8" size booster
Also, for the E brake cable from a C68 Lancer:
You need
MB520346 for the right
MB520345 for the left
If you use the C53 cables you need to reroute them because is 1 inch short approximately !
I hope its help for your swap..."
In summary, in the USA, the C53A and C52A proportioning valve is MB699640. This is the correct proportioning valve for a drum brake sedan that is converted to rear discs or you want more rear bias.
The MB699642 is the stock proportioning valve for the drum brake sedans C62A, C63A, and E18A (Galant Sigma 87-90ish). Not sure how or why the 1.6L N/A sedans with rear disc brakes would use this same proportioning valve.
 Post subject: Re: WTB C53A prop valve
PostPosted: Wed Jun 04, 2014 4:12 pm
Got the last one from the mitsu warehouse in Atlanta. They said there was one more at a dealer in Florida. They weren't sure if they could order more from Japan.
Will post results of going from the rear drum prop valve to this one.
PostPosted: Thu Jun 05, 2014 7:23 pm
First impression, braking is noticeably different and better. Feels more balanced, I don't feel the urge to gently pull the ebrake cable to "equalize" the braking.
After some driving and spirited braking the front and rear rotors seemed equally hot. Before, I don't remember the rears being much more than cool or warm.
PostPosted: Thu Jun 05, 2014 7:55 pm
I though you where running a 1g prop valve?
PostPosted: Thu Jun 05, 2014 7:59 pm
Nope. It wouldn't be a bolt in affair.
I'm running:
93-96 Mirage booster - much thinner and only way the Magnus cast intake manifold will fit
2G AWD master cylinder
Front Rallyguy big brake kit - 4 piston Wilwood dynalite front calipers, GVR4 slotted rotors and BP-20 pads.
Rear slotted GVR4 rotors, EBC red stuff and 1G/GVR4 calipers
Stainless brake lines on all four corners
ATE superblue DOT4 fluid
PostPosted: Fri Jun 06, 2014 11:45 am
Did you notice any difference in the bias before the big brakes where put in the front?
Or I guess the question is; is the bias supposed to collate to the size difference or braking capacity difference between the front brakes vs the rear brakes?
PostPosted: Fri Jun 06, 2014 11:51 am
With the drum brake prop valve and the big brakes it's way off. With the new prop valve it's better, but not ideal. I'm sure I'd need an adjustable one to be perfect.
PostPosted: Wed Aug 02, 2017 9:40 pm
I have just placed an order for the MB316180 or MB699640 (# superceded to) and it should be coming from Japan. Lots of little parts were populating with amayama but 80% probability of stock turned into no longer in production. That is fine for gas pedal return springs and other little do dads, but the brake proportioning valve comes up with the part number change from original and the order is processing. Also sadly, the hood insulator is no longer available from that avenue of ordering. I am however getting the retainer wire forms brand new.
My prop valve is just fine from what I can tell, but I would like a backup.
PostPosted: Wed Aug 02, 2017 10:02 pm
I'm running the prop valve from a 3g eclipse GT, it looks a lot like the stock unit, only bigger slightly then the drum version, but now I wonder what the difference is from using the genuine "89 C/M GT unit... ...oh well I suppose I used the right valve, the more I think about it I am using the dual piston front brakes, and the 2001 gt eclipse that I pulled it from had the twin pistons up front, and the rear discs.
Abe
PostPosted: Sat Mar 17, 2018 7:19 am
The only thing the proportioning valve does is provide a split point for pressure and volume of fluid going to the front and rear brakes, this can change how the brakes react. If you can find the split point information for the car you removed one from, then you know what information to work with and how it affects your system.
