It is currently Sun Oct 19, 2025 7:48 pm
PostPosted: Thu Jun 05, 2014 10:49 am
Hey Guys,
Do you know if 4G63T Cam Gears Pulleys fit on a 4G61T? I need to replace mine and saw a couple of 4G63's Stock one on sale.
I also need to change my Timing Belt but i've heard that it is shorter on the 4G61T.
Thanks in advance.
PostPosted: Thu Jun 05, 2014 1:19 pm
The timing belt is definitely shorter by a few teeth on the 4g61, but I'm not sure about the cam gears. I'd imagine they are the same?
PostPosted: Thu Jun 05, 2014 1:58 pm
yeah the gears are the same.. the 61 block is shorter than the 63 so you need a shorter belt... the 63 uses a 167 tooth belt.. the 61 uses a 165 toothed belt.
PostPosted: Fri Jun 06, 2014 9:39 am
Thank you
PostPosted: Fri Jun 06, 2014 9:40 am
Thank you for the info mate!
