It is currently Sat Oct 25, 2025 11:31 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Tue May 27, 2014 11:50 am
I do not believe the clusters on the 95 are interchangable with the 91's as they are different shapes. I had a 91 Summit LX auto and it had a tach cluster from the factory they are just a bit hard to find as they did not sell a ton of them as the auto's were pretty anemic.
91
http://i.ebayimg.com/t/OEM-91-92-MITSUB ... B/$_35.JPG
95
http://images.hollandersolutions.com/JO ... /3HF/2.jpg
Also the bolt pattern is different (91 = 4 x 114.3, 95 4 x 100) so you would definitely need to swap the hubs.
PostPosted: Tue May 27, 2014 1:17 pm
Sorry I meant he could sell it to a 4g guy since they are hard to find. I knew it wouldn't fit the 3g cars.
PostPosted: Tue May 27, 2014 9:15 pm
I understood about the cluster, i may pull it. The auto at the yard had no tach but good to know they are out there. I pulled a 4g shifter and will install eventually. I will grease it and maybe paint it not sure about the paint but its kinda rusty so i wire brushe it for a while still needs more tho. The shifter was only $16 bucks tho it will be awesome once its in.
94 Mitsubishi Mirage "4dr"
PostPosted: Wed May 28, 2014 9:48 am
I'd check the plastic bushings in that shifter. Every 4g one I've came across the bushings were shot or missing all together. I usually tear down a 91-94 dsm shifter at the yard and get the bushings. The lower ones are usually like new but the two on the shift lever itself will have wear. They are all the same bushing though so you may have to go through a few dsm shifters.
PostPosted: Wed May 28, 2014 7:18 pm
Brass shifter bushings can be had new for about the price of a used shifter.
Replacement bushings are a few dollars each and if you check my member thread, can see what part numbers they are and how many were used.
Combine them and it's a steal compared to aftermarket shift equipment.
PostPosted: Wed May 28, 2014 10:52 pm
They must be missing im not sure what bushings you guys are talkin about, the 4 bolt rubber bushings are great.
Can you explain a bit different for me? I want to rebuild it and paint it even tho its hidden it needs some cleaning up
