It is currently Sun Oct 19, 2025 11:03 pm
PostPosted: Tue Feb 18, 2014 5:11 pm
I have an 89 colt that has no exhaust on it. I was wondering which downpipe bolts up (if any) to a 4g63 swapped colt.
PostPosted: Tue Feb 18, 2014 5:22 pm
Depends on the transmission and o2 housing. Keep in mind that there are no off-the-shelf downpipes for use with Colt/mirages that have been swapped, you simply make use of the corresponding DSM component.
PostPosted: Tue Feb 18, 2014 5:25 pm
I believe a 2g fwd downpipe is what you need, the 2g awd DP will work also but the fwd clears a little better.
PostPosted: Tue Feb 18, 2014 6:48 pm
I'm using a 3" 1G AWD downpipe, but the FWD would fit better.
PostPosted: Tue Feb 18, 2014 7:07 pm
Thanks guys. I'll get a FWD downpipe and modify it accordingly.
PostPosted: Tue Feb 18, 2014 7:18 pm
I am running a 2g 3" fwd downpipe. Not modified.
PostPosted: Wed Feb 19, 2014 3:26 am
2g fwd downpipe: If you want to tuck the exhaust into the driveshaft tunnel, use this one as it puts the outlet right into the tunnel. Doesn't need to be modified and one of the exhaust hangers will pop into a stock exhaust hanger.
http://www.ebay.com/itm/1995-1996-1997- ... 5f&vxp=mtr
2g awd dp: Use this one if you plan on doing an awd car as it doesn't have as much of a kink which puts the exhaust off to the side of the tunnel.
http://www.ebay.com/itm/95-96-97-98-99- ... 0c&vxp=mtr
PostPosted: Wed Feb 26, 2014 7:42 am
I ended up using a 2g FWD downpipe and had 0 issues with clearance. Thanks again everyone
PostPosted: Thu Apr 10, 2014 12:39 am
What about from the down pipe back? Mines a custom job but does anyone have and easier suggestions? Like 1g FWD or 2G FWD rear sections? Trying to get a new exhaust since this welding on mine is terrible and only 2.5"
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Thu Apr 10, 2014 2:26 am
nope only the 2g fwd downpipe is a fit.. from there back it has to all be custom..whether u have a shop make it from scratch.. or u have a premade kit cut to fit. personally I would have a shop make it to how u want.. will cost about the same and exit where u want it to.
PostPosted: Thu Apr 10, 2014 4:12 am
I did a Y pipe, one end leads to an electric cutout, the other leads through a long glasspack then a turndown before the axle.
