It is currently Tue Oct 21, 2025 8:03 am
PostPosted: Mon Dec 16, 2013 5:31 pm
hi guys...
im in the process of installing a new front mount intercooler. and was just wondering what the outlet size of the td04 is on a 4g61t... and the intake size... i thought it was 2.25 but after looking online im coming up with different measurements all over....
thanks
PostPosted: Mon Dec 16, 2013 5:57 pm
hey i just measured it and it seems to be 1.75 inches but i thought it would be 2.25 (measured with hose on ... idiot)
sooo my intercooler has 2.5 inch inlets... what i was thinking of doing it simply running 2 inch piping but at the outlet of turbo and intake ill have a 1.75 - 2 inch reducers and at the intercooler 2 - 2.5 inch reducers....
would that be to much of size changing or should that be fine?
is there a mod i can do to increase my intake and outlet sizes?
for example i was thinking of getting some pipe expanders and expanding the outlet of the turbo to 2 inches but iam unsure if i could do that with the intake to?
thanks
PostPosted: Mon Dec 16, 2013 5:59 pm
the stock J pipe coming off the turbo is 1 3/4" inside diameter (I have the pipe and turbo in front of me now) and the intake part going into the turbo from the air filter is 2"
PostPosted: Mon Dec 16, 2013 6:03 pm
my setup has the 2 1/2" IC piping also... I have a 2' to 2 1/2 coupler at the J pipe.. and all my ic pipe is 2 1/2.. it is loose fitting but I used 2 clamps and it seems to clamp down good and hold 16 psi.... but im sure you can buy a 1 3/4 to 2 1/2 coupler..
PostPosted: Mon Dec 16, 2013 6:09 pm
hey thanks for that.... so do you think stepping from that to a 2 inch piping then to a 2.5 inch intercooler is ok or is that a bit to big?
NEVERMIND!
you answered at the same time :)
PostPosted: Mon Dec 16, 2013 6:14 pm
by the way what about the pipe expander idea?
PostPosted: Mon Dec 16, 2013 6:19 pm
I personally wouldnt do it.. to many connections = more places to leak.
I would try to find a coupler either 2 to 2 1/2... or a 1 3/4 to 2 1/2..
PostPosted: Mon Dec 16, 2013 6:33 pm
slowdsm
do you mean run 2.5 piping all the way through to the intercooler?
so you think get 2 - 2.5 couplers as for the outlet on the turbo and the intake manifold... i cant find any 1.75 - 2.5 reducers... thats why i thought of expanding the pipe that little bit if it goes....
I am trying to avoid to much lag by pipe sizing if i can
one option i was thinking is...
get silicone reducers from 1.75 to 2.125 (all i can find)
stretch the 2.125 over the 2.25 (i think itll stretch)
run 2.25 piping to the intercooler go from 2.25 to a 2.5 then out of the intercooler go 2.5 to 2.25 then run back to the intake 2.25 all the way and use a reducer again 1.75 to 2.125 and stretch it over....
i was hoping that minimizes lag?
other thing i could do is expand the outlet of the turbo to maybe a 2 inch (i still dont know if i could do that never expanded a pipe but i found these on ebay http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 1005098541 and thought that might work)
then go from 2 to a 2.25 run 2.25 pipe all the way through and just get reducers from 2.25 to 2.5 on the intercooler?
or does the pipe size from 2 to 2.5 not really produce much more laG?
PostPosted: Mon Dec 16, 2013 6:41 pm
yeah come off the turbo with a 2 to 2 1/2" coupler..then run 2 1/2" pipe to the IC and up to the throttle body...the 2" will clamp down onto the J pipe good just use 2 hose clamps on it..
this is the J pipe.. as u can see there are 2 bumps.. put both clamps in between them and it will seal up good..
http://i548.photobucket.com/albums/ii33 ... AG0438.jpg
as for the intake.. u can make it however u like.. im going from 2" up to a 3 1/2" filter.. this is not as crucial as the IC piping so you can make it however large you want to.. alot of people use a 4" filter
PostPosted: Mon Dec 16, 2013 6:43 pm
sorry when i say intake i mean not the turbo intake but the actual intake on the motor so after the intercooler and bov
PostPosted: Mon Dec 16, 2013 6:47 pm
this part correct?..
http://i166.photobucket.com/albums/u101 ... wImag3.jpg
if so most people upgrade to a 2g dsm one which is 2 1/2..
PostPosted: Mon Dec 16, 2013 8:51 pm
thats the one .......
2g dsm u say?
whats that part called? and where do i find one in australia ?
if i call a wrecker what car is that out of?
would a bigger throttle body be an idea with that or not worth it yet?'
such as this 1
http://www.ebay.com.au/itm/Universal-Up ... 0fd&_uhb=1
PostPosted: Mon Dec 16, 2013 10:47 pm
stock throttle body is good..
part is called a throttle body elbow.. the 2g dsm is 95-99 Mitsubishi eclipse/Eagle talon.. with a 4g63t engine.
http://www.ebay.com.au/itm/2g-Throttle- ... 338895a960
PostPosted: Tue Dec 17, 2013 12:50 am
sweet thanks im on my way to get one now :)
thanks for all the help!
PostPosted: Tue Dec 17, 2013 6:38 pm
wreckers told me over the phone they had one ... but offcourse they had no clue what part i was talking about till i brang it in.... and they didnt have it...
so now im getting the one from the link thats you supplied above :)
3 weeks wait is a little anoying though... thats probably why this car is taking me so long because i keep having to order parts online
