It is currently Wed Oct 22, 2025 5:16 pm
 Post subject: boost gauge install
PostPosted: Sun Nov 10, 2013 5:45 pm
hey there,
just got a question re boost gauge install.
i have a 4g61t n was just wondering which line top use for boost gauge.
has anyone got a pic ?
thanks
 Post subject: Re: boos gauge install
PostPosted: Sun Nov 10, 2013 7:11 pm
tee off the fuel pressure regulator line.
PostPosted: Sun Nov 10, 2013 7:29 pm
sorry but which one would that be? iam still learning re this engine
PostPosted: Mon Nov 11, 2013 8:34 am
The gold/silver hat (FPR) at the cam gear side of the fuel rail, it has a rubber line going to it.
PostPosted: Mon Nov 11, 2013 1:04 pm
it has 2 lines.. the small line is the vacume line you tap into for the boost gauge.. the larger line is the fuel return line.. do not tap into that one lol..
PostPosted: Mon Nov 11, 2013 3:51 pm
^ lol good point.
PostPosted: Mon Nov 11, 2013 4:29 pm
thanks guys.. but has anyone got a pic? I dont seem to be able to find this gold silver hat
PostPosted: Mon Nov 11, 2013 5:12 pm
It's right here bro!
PostPosted: Mon Nov 11, 2013 5:18 pm
awesome thank you :):)
now i can see what little hat thing u guys meant
PostPosted: Mon Nov 11, 2013 5:21 pm
No problem!
Remember, use the small vacuum hose. If you pull the hose off and fuel comes out, you have the wrong hose!
PostPosted: Mon Nov 11, 2013 5:27 pm
lol yeah thanks ill make sure not to lose to much fuel...
btw whilst were at gauge installs, im about to install an oil pressure gauge to. do i just remove the original sensor and put the new one on? or do i need to T Piece it?
and just in case which one was it is it under engine right hand side under the cam gear?
PostPosted: Mon Nov 11, 2013 7:09 pm
When installing oil pressure gauges I prefer to use one of the numerous ports found on the head. There are multiple machining access holes on the head that are blocked up with allen-headed plugs. Pull out the plug, thread in a matching metric adapter and install the gauge hose.
