It is currently Thu Oct 23, 2025 5:15 am
Post new topic  Reply to topic  [ 41 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: Tires
PostPosted: Wed Oct 16, 2013 11:09 pm
Check my build thread, I'm running 225/50 on a +34 offset, it's flush in the rear and sticks out a tad in the front.
Have you actually driven the car like that? I have a feeling it would rub. I had rubbing issues with 225/50's on a +40 offset that was 7" wide, but my car was also lowered a bit
PostPosted: Thu Oct 17, 2013 7:50 am
I've rallyd the car around pretty good like that with no issues. By looking at it it seems like it would rub in the front, the rears clear by a nut hair so no issues there. I think the car has a bit of natural camber in the front when braking or cornering hard so it tends to clear, I've been expecting it to rub and if it does I'll roll the fenders a little bit. It has Mirage KYB struts and I'm not 100% sure on the springs. I'm also not sure how much the floating rotor conversion changes the foot print, that might have something to do with it. +34 would be the absolute lowest offset to go on 225s that's for sure. Also 225 can be different widths depending on brand and style of tire.
PostPosted: Thu Oct 17, 2013 9:16 am
I've had tire rubbing on the inner frame rail areas under near lock steering.
Tires were 205/50-15 on a +42 offset rim. You don't want any rub on fenders or frame.
PostPosted: Thu Oct 17, 2013 3:52 pm
So +38 seems like it could be the happy spot for 225s.
PostPosted: Thu Oct 17, 2013 4:28 pm
+40 offset is the perfect offset for these cars, all around.
PostPosted: Thu Oct 17, 2013 9:49 pm
would this mean that the 195/50/15 w/ 6.5" width and +40 offset would be the best choice. how about having different tire size in front 15's and 16's at the back any negative feedback on this. I see evo's on this kind of setup
PostPosted: Thu Oct 17, 2013 9:54 pm
Biggest rear axle/tire to fender clearance issue, is the lowering of the rear end via springs. This leaves the panhard rod shunting the axle over ever so slightly closer to one fender more than the other due to its arc of travel. You need an adjustable panhard rod. Heck, I need one and completely forgot about it!
PostPosted: Thu Oct 17, 2013 9:55 pm
You wouldn't want to run different diameter rims like that. The car would understeer badly with 15's up front and 16's in the rear. It's popular in FWD cars to do smaller wheels in the rear, because this can promote oversteer. I don't know how EVO guys are doing this. Usually different rolling diameters on a AWD car will break drivetrain parts.
PostPosted: Thu Oct 17, 2013 10:23 pm
thanks that clears it up. its a big NO.
back to my question. would the 195/50 15 be the best option for stock suspension? what about for those w/ lowering springs what tire size would be the best for 15's
PostPosted: Thu Oct 17, 2013 10:30 pm
You can do 205/50's without any problems.
PostPosted: Fri Oct 18, 2013 9:49 am
:salute:
PostPosted: Sat Oct 26, 2013 8:17 pm
I have 2 sets of wheels. Both 17×7. One has 225/45/17 other is 235/40/17. Only had a tiny bit of rub full lock on frame.But after knknocking off the undercoat doesn't anymore.
PostPosted: Sun Oct 27, 2013 7:44 am
^offset?
PostPosted: Wed Nov 06, 2013 2:12 pm
has anyone had any good/bad experiences with FALKEN FK-452 tires? they seem to have a good semi soft rating im looking for.. and I found a set for a very good price.. 68 bucks each... but need input if there good tires or not.
thanks much
PostPosted: Wed Nov 06, 2013 2:38 pm
thanks much
Honestly, I think they suck. I've driven cars with them before. You're going to have a pretty powerful vehicle when it's all done, you're going to need something more sticky, like at least under 300 treadwear. Tires aren't something worth cheaping out on, in my opinion. You don't have to spend a fortune, but I'd look for something a little bit nicer.
