ok so before the rebuild I developed a shake when turning left under acceleration. The shake only occurs with left hander but I cant tell if its the right or left wheel that shakes. after rebuilding the stuff listed below it has started shaking on bumps and still on left turns. The suspension is K-sport coilovers with adjustable camber plates,
Things I replaced 3 weeks ago:
Left ball joint (old one was shot)
Left axle with a 1 piece Mirage turbo piece (old one was shot) [no its not the two piece and was the same as the one I had before with no issues]
left wheel bearing and seals (old was shot to hell)
Left and right tie rod ends
Left and right sway bag end bushings
Aligned the car professionally at my usual place and had the front rims re balanced...
Both axels have no side to side shake and the right wheel bearing and ball joint are fine. the wheels steer together and there is very little play in the steering... F'in stumped guys
After replacing all of this the damn car still shakes when turning left and on big bumps. other than replacing the steering rack and inner tie rods Im not sure what else to do... thinking inner tie rods but they seem to check ok. ANYONE GOT ANY IDEA? or if your in SoCal we can meet for a test drive to try and figure out what it could be
