Doing some reorganizing of the garage and wanting to get rid of this stuff. Please help me make it all go away.
Here's the lot of mostly Mitsu stuff.
[image]http://www.galantvr4.org/img.php?id=145795&width=400[/image]
[image]http://www.galantvr4.org/img.php?id=145796&width=400[/image]
Starting from the top left:
Colt specific stuff:
Stock Colt turbo flywheel,clutch setup. Good shape $40
Colt turbo intake pipe and bov recirc tube. $30
Colt turbo charge piping. $25
2 Colt pass side corner marker lights, one missing spring. $20 and $15 respectively
Colt turbo front/rear engine mount brackets, needed for 4g in a colt, sandblasted and painted. $40
DSM specific stuff:
1 91 coil pack, 1 90 coil pack. I can measure resistances upon request. $25 each
91 ignition transistor. $15
1g o2 housing. $20
MSD DIS-2 ignition, coil, and wire set for 2g. I don't believe the MSD operates, not sure why. $50
JDM 1987? GVR4 double board ecu. Has GVR4 specific mounting base. $75
1g non working non-eprom ecu, 1g ecu case, and Evo 1 ecu. Make offers
2g awd rear calipers. $40
GVR4 brake master cyl with reservoir, 1" bore. $25
2g alternator. $40
2g timing belt mount, notched for 6 bolt swap. $20
2g ac compressor, bracket, and tensioner. $50
6 bolt fwd and awd starter plates. $10 each
Evo specific stuff:
Evo VIII spark plug coil cover $15
AMS Evo X, Ralliart new front motor mount insert. $25
Ralliart rear upper control arm, new $40
EVO VIII rear struts. $75
Other makes:
Hyundai Veloster OEM all weather floor mats: $40
Chevrolet OEM all weather floor mats (still trying to figure out which model): $30
Pretty much everything I can do shipped at asking price as long as shipping doesn't cost more than I'm asking!
Feel free to ask about item details and close up pictures.
