It is currently Mon Nov 03, 2025 8:46 am
 Post subject: I'm stumped
PostPosted: Sat Nov 03, 2012 10:03 pm
Ok, I have been working on DSMs for long time now so I have ran into so many problems before besides this one. Well, my brother has a 92 awd talon with:
Rebuild 6 bolt block with 8.8:1 venola forged pistons
1g big rods
Stock crank
Balance shafts removed
Stock head (rebuild)
Arps head studs
Felpro head gasket
272 web cams
PTE 50 trim turbo
3 inch exhaust
Sbr exhaust manifold w/ 38mm waste gate turbonetics
Fmic
Greddy type s
Egr block off
Lower half of throttle body block off
Greddy catch can
Ecmlink v3
2g maf
Extrude honed intake manifold
6 bolt intake heat barrier from magnus
Denso 660s injectors
255 walbro
AEM wide band
So here is the problem, the car for what ever reason runs good on a cold start then once
the engine gets hot now starts running pig rich all the way to 10 on the wideband. I did a boost leak test and fix small leaks but currently no leaks what so ever! Brought the fuel pressure down to 28psi and nothing. Swap injectors to 450s, nothing. Made sure base timing was set with timing light, set! Make sure TPS was set correct,set! Double checked my wiring for the 2g maf, check good. Make sure turbo is working, check working good. Stock oxygen sensor is work great, (brand new). So idk I don't get it! What is telling the ECU to run rich?
Any thoughts or suggestions will help me out greatly.
 Post subject: Re: I'm stumped
PostPosted: Sat Nov 03, 2012 10:22 pm
Sounds like a tuning issue via link that is your issue. If you run fine at full rich (cold start), then the ECU is supposed to lean the mixture out as things warm up, in segmented blocks until a preset temp, then I would suspect a tune spec is input wrong or something.
When did it start running like this, and were any changes made at or before that time frame?
PostPosted: Sat Nov 03, 2012 11:06 pm
Nope, what gets me is when it does this if I hold the throttle for a little while, then it will stay idling then slowly go to 11.2/11.5/12.1 and etc... to 13.7 to 14.8. As soon as you snap the throttle once, it will stall, then start it up again, and the same thing happens again. It's so bad if you try to drive the car it stalls, like 10 times,lol. Idk I never had a DSM run like this. :evil:
PostPosted: Sun Nov 04, 2012 8:56 am
Tried the link forums yet? Haha
PostPosted: Sun Nov 04, 2012 9:22 am
One of my old dsm's did something similar after it warmed up. Ended up being the TPS, I put in a good working one and adjusted it and it was fine after that.
PostPosted: Sun Nov 04, 2012 9:38 am
The TPS is working, and I made sure it was set right. I could replace it and try it. I'll try anything right now at this point,lol.
PostPosted: Sun Nov 04, 2012 6:51 pm
What does the front O2 sensor read when all this is going on? What about the coolant temp sensor? Could there be a fuel leaking past the diaphram of the fuel pressure regulator? Does the MAF display a normal amount of airflow per rev at idle? Got a log?
PostPosted: Sun Nov 04, 2012 9:10 pm
My TPS was working correctly too but once the car warmed up it would start acting up. Not saying this is your problem but I would swap in another one just to eliminate that as the problem.
PostPosted: Mon Nov 05, 2012 12:56 am
The coolant temp sensor is showing its working on link, the fpr is a buschur that bolts right on the rail.
PostPosted: Mon Nov 05, 2012 12:49 pm
Could there be a fuel leaking past the diaphram of the fuel pressure regulator? (It would flow into the manifold via the FPR vacuum hose)
Got a log?
PostPosted: Mon Nov 05, 2012 10:52 pm
Got a log?
I should of paid attention to the readings, but I know it's cycling.
FPR, I didn't think of that, that's a good one I would have to check that.
Now, I wanted to switch it to HZ but I don't know how.
Ok, so everyone knows, I'm new to ECMLink so to log I know more or less. I can't help I'm a old school DSMer,lol. Give me a SAFC 1 and I can tuned the shit out of it,lol.
