It is currently Mon Oct 20, 2025 12:57 pm
Post new topic  Reply to topic  [ 268 posts ]  Go to page Previous 13 4 5 6 718 Next
 Post subject: Re: 91 Eagle Summit AWD
PostPosted: Mon Aug 13, 2012 1:36 pm
Yeah buddie!!!
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Tue Aug 14, 2012 6:23 am
see u at the shootout JP
Warren
PostPosted: Mon Aug 27, 2012 6:36 am
The car did not make it to the shootout, because we simply ran out of time with the vehicle.
Here are some shots of it , excuse the multi colored set up
it is border line dangerous to drive at this point, as the alignment is waaaaay off, something that we will need to address shortly
some completed engine bay shots,
The glory hole
Kevin and I scored some cool stuff at the junk yard, and basically completed the interior in the car
the rear seat uprights will require some massaging but that will happen later
Here is a shot of the gauges we are running
and finally the ride height which is way too low..
more to come as always
Warren
PostPosted: Mon Aug 27, 2012 10:33 am
That's quite a multicultural gauge selection you've got there. :lol:
PostPosted: Mon Aug 27, 2012 11:25 am
Yeah no kidding, a couple Defi, an aem and some mis matched autometers :D , but thats all we had in the goodie bin ;)
Warren
PostPosted: Mon Sep 10, 2012 9:59 am
Threw some 10" eibach springs on the rear and now the ride height is acceptable. bump steer is complete junk on the car, It has also been aligned for its current ride height. We hope to have the car at the track within two weeks.
Warren
PostPosted: Tue Sep 11, 2012 10:58 pm
Looking good! Too bad it couldn't make it too shootout but it was nice meeting all of you guys. I'm liking the gauge set up been waiting to do something like that for a while. Good luck and take videos when you get it going!
PostPosted: Wed Sep 12, 2012 9:48 am
it was good to meet you as well aaron, we had a great time at the shootout, for once it was a relaxing affair; normally we are running around with our heads cut off inorder to make the cars go down the track. :)
The car runs on a stock flashable 2g ecu, so we are adjusting the injector scaling and latency values, as well as setting the load columns and fueling tables as well. I will definitely try and get some videos :)
Warren
PostPosted: Mon Sep 17, 2012 6:50 am
The car is finally registered, for an awesome 20 dollars a year .:) For the most part , I have been trying to work on the driveability tune of the car, it seems to have an weird Throttle hang condition, at a specfic temperature.
here is a pic of our connector installed for easy access.
a quick picture of the dump tube out the hood and a shot of the turbo assembly with radiator clearance. Temps were right around 190 degrees.
I also figured that I would do a little painting, The color doesn't quite match, but I think I will do the entire car in this color
nothing like painting in the grass
and on the car
more to come later.
Warren
PostPosted: Thu Sep 27, 2012 9:34 pm
I love that eclipse, it's a inspirational to me to get my 92 talon to the level your beast is, pure sex. But anyways, the summit is looking really great and looking like it was like that from the factory,lol. Great work, keep it up!!!!
PostPosted: Wed Oct 10, 2012 6:28 am
^ thanks I appreciate it.
Did some tuning over the weekend, on gate pressure 21 psi, Virtual dyno numbers are coming back as 400 Hp 400Tq, assuming 2400 pounds of weight. I think this number is a little exagerated, but let me just say, that it definitely moves out.
On the launch control at 5000 rpm, I am seeing 12 psi of boost, which just shreds the tires in 1st and 2nd.
I also added a magneflow Bullet muffler in the middle of the car , finishing it off with a glass pack from Summit racing. Pics of that coming soon.
Warren
PostPosted: Sat Oct 13, 2012 8:57 am
Weighed the car yesterday at the salvage yard, it came to 2620 with me in it ( 170) and 5 gallons of gas,
So this pig is 2450 with out me and street trimed. suprisingly heavy..
Warren
PostPosted: Mon Apr 22, 2013 1:52 pm
Have not updated this is in a while. But loads of progress with the car. We have added
Windshield wiper motor circuit
Heater control circuit
Fixed the tach
added a true boost AEm Controller
Replaced the brake booster so we have power assisted brakes now
Replaced one of the dying 255 pumps
We made the switch to ethanol, maxing the turbo out ( somewhere over 30 psi, settling to 27 psi) here is Virtual dyno pull
The pull was done in 4th gear, because the car is utterly useless in third gear, so tuning it is combersome to say the least.
There is still work to do in the spool up area, as you can see in the trace it is very rich.I will say that this car is borderline dangerous on the street with the bump steer and that has to be addressed soon.
Currently on the hunt for a set of light weight wheels vs the laser meshies
Warren
PostPosted: Tue Apr 23, 2013 10:28 pm
Looks like she is making pretty good power!
PostPosted: Wed Apr 24, 2013 9:23 am
Its doing ok aaron, Trying to set up this car to run against my evo..
so here is the race scenario:
My evo makes roughly 730 HP weighs roughly 2900 with me in it , will be running with 255 35 18 rubber ( 10.80 car)
My summit makes rougly 490 HP weighs roughly 2620 with me in it, will be running QTP 26 by 9.5 slicks ( no et yet)
who do you think will win :lol:
Warren
