It is currently Wed Oct 22, 2025 10:34 pm
PostPosted: Sat Aug 18, 2012 10:02 am
Just like the title says. Both pair are rust free and in good working condition, just need some cleaning and paint to be perfect.
Paypal is 89mirageman@live.com
PostPosted: Fri Aug 24, 2012 6:29 am
One pair sold, one still available.
PostPosted: Thu Sep 13, 2012 12:18 pm
will these work with our vans? any other parts needed?
PostPosted: Thu Sep 13, 2012 12:30 pm
Grab a set of 276mm rotors for a 91/92 Galant VR4 and the matching pads for the calipers and they are a bolt on deal. It would be wise to upgrade to a 1" bore M/C as well but my wagon has abs and rear discs so it came with one already. I actually cleaned up the other pair and put them on our 92 Eclipse since it needed some brakes up front anyway but I can grab another pair if you don't have any local. I actually spotted a nice clean pair the other day at the yard but forgot to grab them.
Oh yeah, you need a minimum 15" wheel to clear them.
PostPosted: Thu Sep 13, 2012 1:19 pm
Got mine thanks. Cleaned these up well too. I'll post up a preinstall pic.
PostPosted: Thu Sep 13, 2012 3:21 pm
Do you have to change the booster as well or just the MC? I don't have ABS or rear discs. And its $65 for a pair correct? Thanks!
PostPosted: Thu Sep 13, 2012 3:30 pm
Booster is fine and you don't have to change the M/C but the pedal will be stiffer with the correct one. Yes, $65 shipped for the pair.
PostPosted: Fri Sep 14, 2012 11:05 am
stock brake lines work too? im sure i'll take them either way....just trying to figure out what all i'll need to make them work. =)
UPDATED: took a look at my car and it looks like the lines i have will work so i'll take them. sending you $ via paypal now. if you have someone else you were talking to and they're already sold you can just send me a refund.
thanks!
PostPosted: Fri Sep 14, 2012 3:22 pm
You're right, oem lines will screw right in. I can get more of these if anybody else needs a set.
