Well I kinda got the car already "built" per say but I will be updating from now on. Where to start I guess a mod list should be first so here it goes...
The car is a 92 eagle summit es so it has/had all the bells and whistles with the exception of the dohc engine. It started life as a 1.5 auto but I swapped it over to manual.
Engine:
6 bolt w/eagle rods wiseco pistons, stock 2g head and cams on a fel-pro gasket with arp's
Drivetrain:
waiting on a 91 fwd turbo trans (destroyed the km210 that was in it) gonna install a sbr insert into it and have a southbend organic/feramic disk and act 2600 pp
Fuel:
walbro 255 re-wired, stock lines w/uprgraded feed and return, aeromotive fpr, precision 1000cc injectors
Forced Induction:
FP manifold, Holset HX35 w/bep bolt on housing, punishment racing o2 housing, ebay 44mm wastegate, ETS street IC,Tial Q, 1g throttle body, 2g intake manifold, sbr manual boost controller
Exhaust:
2.5 to 3" downpipe, 3" bullet style cat, 24" resonator with a turn down
Electronics:
gt wiring harness, 90 electronics, ecmlink v3 on speed density, aem wideband
Cooling:
afco scirroco style radiator, 16" slim fan
Suspension:
19 year old garbage springs and shocks, yoshi fab front and rear strut bars.
Here are a few pics from the build,
how I received it
engine coming out
out
5 speed swap was time consuming!
ran the wideband through the fender
ets street kit
I need to get a current shot of the engine bay since I switched over to speed density. And here is whats left of my km210 I broke last week.
