It is currently Thu Oct 23, 2025 1:52 am
PostPosted: Tue Jun 26, 2012 10:12 pm
Because Race Car
This is the last of the parts from the rally colt that won't be used and should go on to someone who will get it back on (or off) the road!
Custom aluminum intake snorkel with '609' 2G MAF, heat shield, catch can with breather, and K&N filter. The filter is bent but isn't broken and could easily be bent back into shape and cleaned. I have no way of testing the MAF but it was working when it was taken off of the car. I also do not know what needs to be done to use this MAF but I think 89Mirageman makes a harness adapter for it :)
I'm not sure how much it would take to fit this into a Wagon but I know someone (ahem Chris) is running his wagon NA at the moment :wink:
Price: $60+shipping
PostPosted: Thu Jun 28, 2012 9:06 pm
Does this fit up to the fender area where the air snorkel is usually pointed? RF?
I seem to remember the front end of of rallyguys colt being tube framed, so just curious if it might fit well into a standard engine bay setup.
I am not opposed to tweaking the panel to make it fit; better than starting from scratch.
PostPosted: Thu Jun 28, 2012 11:32 pm
Because Race Car
You're almost there Tim :D I can't say 100% that it is placed where the original snorkel is but it is VERY close. This originally mounted with two bolts on some of the tubular forward bracing seen here:
I tried to mock it up as my car sits now but I can only get so close. Chris modified this after the above picture was taken but the same two mounting holes are there. You can see them below the Motul sticker in this picture:
Here are a couple more:
I'm not trying to get rich off of this but I don't really know what to ask for it and I also don't want to throw it away. It's kinda part of our history and I'm a nerd like that :lol: If someone wants to make me an offer and it's not entirely insulting I'll probably take it because I have no other use for it.
PostPosted: Sat Jun 30, 2012 1:15 pm
I will post up a pic of my engine bay, because I have been looking to create a piece for this corner.
This might work out well for me:
I have a 2G stock snorkel in there, and it is a close fit even with that little extension you can see at the inlet to the turbo.
PostPosted: Sat Jun 30, 2012 3:19 pm
Because Race Car
Yeah I see what you mean with the 2G snorkel - it's pretty tight in there. If you are interested in just the shield or some other parts I'm not above separating things. I just really don't want to throw the whole thing away :(
PostPosted: Sun Jul 01, 2012 9:34 am
I will take the:
metal shield (comes with the adapter to fit the 2G MAF to the plate too?),
catch can
metal tubing
blue coupler
3 hose clamps
I don't want the 2G MAS with snorkel, the air filter, nor the relays.
PM sent with shipping details.
PostPosted: Sun Jul 01, 2012 3:31 pm
Because Race Car
pm'd you back Tim
