Appreciate the response... Yea mine shifts great just engages right off floor.. Did yours engage right off floor or did you have that play before it engaged?
.608" to .610" is ideal for DSM performance clutches. I had it resurfaced within specs. Everything is replaced, Except I never replaced the pivot ball or clutch fork. It looked fine to me. The clutch fork when clutch is not pressed in, is in the middle. It shifts great, except there is no play in the clutch pedal, when pressed in all the way to floor, the shift fork is against the housing, and cant be pressed in that extra bit. And engages right off floor before being released all the way..
replace pivot ball/ shift fork? Extend slave rod? But extending slave rod is putting more stress on tob, fork etc.. Everything was done correctly,
I just never shim the pivot ball, & reading some posts seeing how people have shim it. Just curious before I go ahead & take trans down. Being at my friends, Noticed when pressing in the clutch it goes against housing & you cant get that extra play. I just dont want it to cause damage to housing. Trying see how many shims people have used
