It is currently Wed Oct 22, 2025 10:38 pm
PostPosted: Wed Mar 28, 2012 6:38 pm
RedJack Racing twin scroll T3 exhaust manifold- Brand new, never ran, only mounted for test fit. Warranty will transfer to purchaser. $700 shipped
Other stuff (everything pictured is for sale, and I need it gone so make offers); http://s1085.photobucket.com/albums/j43 ... lt/Mirage/
1g FWD front struts- $30
1g FWD rear stabilizer? bar w/ poly bushings- $15
1ga Eclipse tail lights- $20
6 bolt AWD flywheel, needs surfaced- $40
2 sets of stock 6 bolt turbo pistons and rods- $20
2 A/C fans- $10 each
2 oil filter housings; one water cooled, one non turbo- $10 ea
6 bolt front case w/ BSE already done using OEM parts, new main seal- $50
4g61 mas- $25
4g61 ecu- $75
1.6 (flat) flywheel- $30
'90 TB- $25
92 GS rear hubs NIB- think I paid $100 or so, $75
NIB Supra pump and sock $100
PostPosted: Mon May 07, 2012 12:02 pm
BUMP
PostPosted: Mon May 07, 2012 12:10 pm
is the stabilizer beam an aftermarket sway bar, or an oem axle beam
PostPosted: Mon May 07, 2012 1:51 pm
I'll take the front case,Pm me how much shipped,Also is the supra pump tje Bosch one??
PostPosted: Mon May 07, 2012 5:25 pm
Will the gs hubs allow me to run disk brakes in the rear instead of drums? If so ill take them.
1991 Plymouth Colt - Project
PostPosted: Wed May 09, 2012 10:16 pm
It's the stock piece that connects the rear axle to the chassis, but its from a DSM and won't work on a CSM.
I'll look into shipping tomorrow. No, Supra pumps are Denso (same as OEM Mitsu).
Yes they will, but you will need thicker brackets that 91talonharv420 has made. Let me know if you'd still want them.
PostPosted: Wed May 09, 2012 10:39 pm
Give me a deal on both thing supra pump and the front case
PostPosted: Sat Jul 14, 2012 11:38 am
Bump. $700 shipped for the manifold.
PostPosted: Tue Aug 21, 2012 8:43 pm
Offers?
PostPosted: Sat Sep 01, 2012 8:01 pm
Manifold SOLD. Everything else scrapped. Please delete thread.
