It is currently Tue Jun 04, 2024 12:06 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2
PostPosted: Mon Apr 30, 2012 12:04 pm
I plan on either slotting mine or something as well so I can use the camber plates to set neg camber for track days. I just though I'd share that mine was perfectly strtaight, zero camber without slotting them.
PostPosted: Mon Apr 30, 2012 1:42 pm
Wanna see my slot job?
PostPosted: Mon Apr 30, 2012 2:16 pm
That's Slotastic!!
George
1997 Nissan 240sx
1970 Datsun 240z
PostPosted: Tue May 01, 2012 10:07 pm
So I got my slot on. This is what it looks like
This is the result and this is fresh off the jack and hasn't moved so I think this will solve the problem atleast as far as getting my wheels flat on the ground. You can see how much my tires wore. The YoshiFab plates are still all the way in. I can't slot it anymore.
Is there something that I'm missing?
George
1997 Nissan 240sx
1970 Datsun 240z
PostPosted: Thu May 03, 2012 8:03 pm
The only difference between yours and mine is that I'm using the CSM hubs and knuckles.
These pics were taken when I had myt old wheel tire set up which was
15x7 wheels/ 40 offset with 225/50-15 tires
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Thu May 03, 2012 8:25 pm
are you camber plates maxed?
George
1997 Nissan 240sx
1970 Datsun 240z
PostPosted: Thu May 03, 2012 11:11 pm
damn near maxed.....
I'll take pics of my plates when I get home
Geoff
89 2.0 Turbo Colt
PostPosted: Fri May 04, 2012 3:07 am
I'm using Colt struts and Expo knuckles, with the stock control arms. My Yoshifab camber plates are almost all the way out toward the fenders (positive), and I still have a tiny bit of negative camber.
I thought I might have too much slot on.
PostPosted: Fri May 04, 2012 5:20 am
I also ground some material gonna the hub behind.the upper bolt. Maybe 1/8" material. But enough to give me a bit more adjustment.
PostPosted: Sun May 13, 2012 7:41 am
Did you spin your camber plates 180 degrees? Like previously said the centerline of the strut seems to be towards the front more so than it should be. Not sure you will gain much room within the strut tower doing this but it is worth a try.
I just went and looked at how far inward my pillow balls are adjusted and even with coilovers I am pretty far in. I have room but that is because the diameter of the spring is a lot less. The coilovers I have also have a slot on the top hole on the mount. Another thing though is I have elantra control arms.
