It is currently Thu Oct 23, 2025 1:55 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page 1 2 3 Next
PostPosted: Fri Apr 27, 2012 5:24 pm
A little history on the car, it use to be redrum123's car. The one that threw out the flywheel during a pull.
I am the 3rd owner since then. It has yet to run but has had lots of work done to it.
As it sits rite now its just a shell , no interior, motor, trans, suspension or wiring. Just has a roll cage, fuel cell and a auto rear end in it.
I have a lot of work to do to it but it won't take me long.
My plans are to finish the awd system, make it 5speed (untill I rebuild the auto trans I have) , take motor and turbo set up from my talon and put it in the colt.
So far I have
Built head with BC springs,272 cams
Eagle/Ross 9.0:1 motor
Jmf smim
FP 3065 BB turbo.
Fmic set up.
Stock 5speed trans with vce installed so I can fwd on dyno.
Act 2900 clutch
Fidanza fw
Fic 1150 injectors
Fpr
Gm maf
Parts I need
Ecm link
Fuel system for fuel cell
And find the rite front axles ( which I'm still unclear about)
Drive shaft.
Pics as it sits.
PostPosted: Fri Apr 27, 2012 5:52 pm
Welcome! You've got a good start with the right stuff. Good luck and keep us posted on progress.
PostPosted: Fri Apr 27, 2012 7:24 pm
I hope you know you cannot use that rearend with a 5 spd trans.. they are different gearing between 5 spd and autos.
but other than that very nice start..and good project.
PostPosted: Fri Apr 27, 2012 7:29 pm
Thank you.
PostPosted: Fri Apr 27, 2012 7:31 pm
I knew that already but thank you.
Taking the motor out of the talon.
Geting closer to being in the colt. Woot. Motor and trans should be on tomarow.
PostPosted: Sat Apr 28, 2012 9:48 am
I need those fenders! ha.. jk..... Nice start to a fun project :supz:
PostPosted: Sat Apr 28, 2012 9:48 pm
Test fit motor. Time to make motor mounts.
My wheel and tire set up I just bought from a guy on Dsm tuners.
PostPosted: Sun Apr 29, 2012 8:34 pm
Scored some two piston calipers from a parts car I have.
Got some Stuff done today took everything out and cleaned the inside and all the pieces.
My gf had her way with a valve cover I like it.
Clean
PostPosted: Sun Apr 29, 2012 8:37 pm
Yayyy fuel system is here.
2 walbro 255hp fuel pumps
2 e85 safe fuel filters
All the 8an fittings and lines I need.
PostPosted: Mon Apr 30, 2012 1:00 pm
Made a bracket for fuel pumps.
PostPosted: Tue May 01, 2012 10:23 pm
Looks like a good start!
PostPosted: Thu May 03, 2012 1:28 am
Yayyy rims and tires are here.
Ran in to a problem when I went to measure for my 1piece drive shaft. :( looks ill b fwd for a while till I get this fixed.
Other then that, I got it all wired up .
Things left to do are.
Get Dsm link
Find a 1g turbo water pipe. If you have one lmk
Finish making rear motormount.
Rear brakes.
Install dash.(somany pieces)
Make exhaust
PostPosted: Thu May 03, 2012 3:23 am
I highly do not recommend a 1pc shaft. Do a 2pc
PostPosted: Thu May 03, 2012 9:46 am
Why's that?
I'm just being lazy and don't want to make the mounts for the drive shaft.
PostPosted: Thu May 03, 2012 3:22 pm
You'll have CRAZY vibations at higher RPM/Speed
