It is currently Fri Jun 07, 2024 1:27 am
 Post subject: Is there a How To?
PostPosted: Sun Apr 22, 2012 4:18 pm
Put piston rings "stock" on the pistons.
The motor is 1990 4g63t Everything is stock.
I have searched through out here and other forums. I had no luck.
 Post subject: Re: Is there a How To?
PostPosted: Sun Apr 22, 2012 6:02 pm
http://www.lilevo.com/mirage/Manuals/4G ... 00-11D.pdf
PostPosted: Tue Apr 24, 2012 7:19 pm
its not to bad, i just did some on a impala motor the other day. Just make sure the piston rings are facing right way.. and have the compression rings so the gap is a 180 degrees opposite of each other so you dont lose compression ... Good luck
