It is currently Sun Oct 26, 2025 9:45 pm
PostPosted: Thu Apr 19, 2012 11:15 pm
hey guys. new to the forum here. i have a question for the more experienced people. i am trying to convert my colt to 5 lug. basically what i did was swap some gsx front hubs and knuckles onto it. which ive read is basically a direct swap.
well now that its all installed. i have extreme positive camber issues..
any input would be appreciated.
PostPosted: Fri Apr 20, 2012 12:22 am
You also have extreme bump steer issues because of the radical change of the tie rod placement. Get Expo knuckles, and camber plates, or just get Expo knuckles and slot your struts a little bit less than this.
PostPosted: Fri Apr 20, 2012 12:23 am
What are you going to do about the rear?
PostPosted: Fri Apr 20, 2012 9:25 am
i have the fwd rear spindles from a 91 eagle.
i tried camber bolts on the front and it corrected it some. ill try slotting the struts out
Last edited by charlesmaley_1987 on Fri Apr 20, 2012 9:31 am, edited 1 time in total.
PostPosted: Fri Apr 20, 2012 9:31 am
Did you research this before doing the swap?
PostPosted: Fri Apr 20, 2012 9:32 am
no not really.. i am a big dsm guy and this is my first csm.
i was told from a few people and previous owner that the gsx knuckles are a direct swap onto it.
PostPosted: Fri Apr 20, 2012 9:43 am
Should do research first. Fronts are simple. Dsm hubs wont fit on rear. You need a certain year mirage sedan rear hubs. Then.you have.to drill to 5lug
PostPosted: Fri Apr 20, 2012 9:54 am
if thats the case the rear can stay 4 lug. idgaf. the shell isn't nearly nice enough to be going through all this hassle.. unless someone wants the colt gt shell, its probably getting scrapped in the next year or so.
PostPosted: Fri Apr 20, 2012 12:23 pm
Rear is a pain..
Put location in profile!
PostPosted: Fri Apr 20, 2012 7:08 pm
heres a few pics of the demon.
PostPosted: Wed Apr 25, 2012 10:47 pm
You dont have to use the mirage sedan hubs for the rear,i use the same CSM hubs.Just take it to your local machine shop and they'll know what to do.
PostPosted: Thu May 03, 2012 1:27 am
grr. anyone have some 4 lug hubs/knuckles they wish to part with.
PostPosted: Fri May 04, 2012 8:37 am
Stock front 4 lug knuckles? I have a pair.. PM me if you want them
1990 Colt AWD 8.8
