It is currently Sun Oct 19, 2025 4:13 pm
 Post subject: Slicks?
PostPosted: Wed May 12, 2010 10:18 pm
I can get an awesome deal on a set of 22.00/8.0-13, and I was if anybody had a experience with them? Also does anyone have any cheap wheel suggestion to go with them? I really cant pass this deal up(only 5 passes on em for 100) and have been looking for slicks. :wink:
 Post subject: Re: Slicks?
PostPosted: Wed May 12, 2010 11:15 pm
under 400 hp, go for it.
diamond racing is about as cheap as you can get in a 13x8 wheel.
more than 400 hp and with a f5m33 trans, go with bigger tires, like a 24x8x15
PostPosted: Thu May 13, 2010 8:26 am
I have mine mounted on volvo spare tire steelies. Full size rim
1989 Dodge Colt E [4g63T]
2005 Saab 92X awd-turbo :)
2003 WW EVO8 FlexFuel
PostPosted: Thu May 13, 2010 10:01 am
Those wheels have the right bolt pattern?
PostPosted: Thu May 13, 2010 10:04 am
Either volvo or saab can't recall but yes. Just need spacers or drill out where rotor bolts are bc rim is not resested
PostPosted: Thu May 13, 2010 3:23 pm
Yea Im running a f5m33 and im pretty sure the car puts down close to 400 the way it sits, as for that I am worried this going shortin my gear ratio up badly. Last time I was at the track 3rd gear was all but used up in the 1/8. The cars rev limiter has been raised from stock to 7750 rpms but I dont think thats gonna stretch the gears much.
PostPosted: Fri May 14, 2010 1:53 am
with 22x8x15's i ran 99.4 mph in the 1/8th in 3rd gear at right around 7700-7800. i have since moved up to a 24.5x8.5x15 slick and would now like to trap the same rpm in 3rd with the taller tire.
if you can trap 99+, go bigger, if not, stay small.
PostPosted: Fri Apr 06, 2012 1:43 am
Y do you guy use a 15?? I"d use a 24.5/9.0/13 tire on a spunwerk rim
PostPosted: Fri Apr 06, 2012 10:55 am
I know a good reason to run a 15" wheel.
