It is currently Tue Oct 21, 2025 4:40 am
Post new topic  Reply to topic  [ 97 posts ]  Go to page Previous 13 4 5 6 7
PostPosted: Mon Nov 21, 2011 11:59 am
yes it is..fan sucks.. outside temps are around 70-75.. car runs about 210.. if I pull over to tune.. after idling for 3-5 min..it will hit about 240.. (only happened once..now I don't sit to tune unless heater is on high).
we are getting a new high flow fan so hopefully that will help some.. the main problem is.. we still have a/c. when I first got the car running I didn't have the front bumper on..so temps stayed about 220 when idling... our plan is to replace the stock colt a/c condenser with a smaller half sized one (if we can find one). to open up a lil more air flow to that side of the car... air doesn't go thru a bumper..i/c..a/c condenser and radiator very well when just sitting lol..
PostPosted: Mon Nov 21, 2011 10:27 pm
Steve what fittings did you use for the -10 an fuel feed line from the tank to the rail.Sorry to ask, i want to know what hardware i need to make that upgrade on my mirage before i lower the tank.
PostPosted: Mon Nov 21, 2011 10:59 pm
the car owner bought a complete setup with lines fittings and filter I just installed it..
if I remember correctly it was something like this
http://www.jegs.com/i/Russell/799/660500/10002/-1
I drilled the hole to size..threaded that thru with the white nylon washers that fit it.. 1 on each side.. and a large fender washer then the nut..
I think I used a barb fitting on the inside to connect it to the pump.
PostPosted: Mon Nov 21, 2011 11:45 pm
Thats waayyy more easier.Thanks
PostPosted: Wed Nov 23, 2011 1:23 am
The car looks Great! For those who have a faded car like this one was, The paint can be brought back to life with a Harbor freight polisher and some expensive polishing compound. You also need at least two buffing pads one being wool for the first cut, second being foam for polishing.
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Wed Nov 23, 2011 3:08 pm
The lines I got off a dude that works at map performance in minnesota very cool dude they upgrade there shop cars often and this setup was from there 1 g awd that was a sumped tank setup got a hella deal for it since they upgraded to a fuel cell, When I have more time Ill put a list of all the farts that are one the car as well as there price Im sure it will be way more than the value of the car, and moe, cant wait to see it from the picks it looks great
89 turbo chili
92 gvr4 96/1000- sold to mois used car lot
PostPosted: Wed Nov 23, 2011 4:55 pm
Please do that!!!!
