It is currently Mon Nov 03, 2025 12:36 am
PostPosted: Mon Oct 31, 2011 2:07 pm
can anyone tell me if a 2nd gen dsm shaft will work for me? I have a 92 colt with 4g63t with a fwd dsm trans and original colt turbo axles. Any help is appreciated thanks.
PostPosted: Wed Nov 02, 2011 4:46 pm
Your factory turbo axles will work with the Dsm trans....if that helps
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu Nov 03, 2011 1:53 pm
I'm not sure if a 2g will work, the transmissions are different than the 1g trans. It can't be that hard to find a 1g halfshaft.
PostPosted: Fri Nov 04, 2011 10:48 pm
one more question, how thick of spacers do I need to make up for the lack of ac bracket?
PostPosted: Fri Nov 04, 2011 11:33 pm
I usually just trim the corner of the ac bracket off and use that as the spacer.
PostPosted: Sat Nov 05, 2011 3:23 am
Use the trimmed a/c bracket or hardened washers. They absolutely have to be hardened washers too, no 5cent regular washers. There's no real set amount of spacing, add/subtract washers until the shaft is spinnable by hand with it bolted down.
PostPosted: Sat Nov 05, 2011 11:06 am
If someone had the bracket lying around, they could measure the depth of the hole?
PostPosted: Sat Nov 05, 2011 1:59 pm
OEM AC bracket thickness = 8mm
8mm SS spacers torqued 29/39 ft.lbs ( FSM )
PostPosted: Sat Nov 05, 2011 7:17 pm
^^^ Awesome!!!
