Can you push in the rod on the slave by hand? If not, then you need to adjust the rod on the master shorter.
I hate to sound like a tard but how do you do that? Just crack the bleeder and push it all the way in by hand?
Edit...I know what you mean, the rod on the clutch itself right? See the thing is when you push the pedal the actuator rod moves but not far enough ti disengage the clutch and when you crack the bleeder it goes all the way to the floor. I think my slave cylinder might be shot because the only time it actually retracts all the way is when the bleeder is loose. Other than that its almost like it won't release the pressure all the way. Its kind of tough for me to explain...
