It is currently Fri Oct 24, 2025 1:31 am
 Post subject: Misc parts 10/07/11
PostPosted: Fri Oct 07, 2011 10:13 am
All prices do not include shipping. Please pm me your zip for a quote. Paypal is 89mirageman@live.com
3g hatch D/S tail light, good condition with no cracks $15
3g hatch front bumper lights $18 for the pair
3g manual shift lever (lever that bolts on only, bracket sold) $8
3g hatch P/S exterior door handle $8
3g hatch P/S door trim $10
3g manual trans mount, note this is for the roll stop part only. Not the one that mounts to the trans even though its pictured, great for auto to manual or 4g63 manual swap $20
MD131263 1.5L 3g CSM ECU, board looks perfect, Ssold
3g csm colt filler panel in great shape $30
(2) 1g dsm 91-94 na throttle body $35 each
1g dsm 91-94 coil pack with plug $25
1g dsm 91-94 manual shifter assembly sold
1g dsm green top CAS with plug $25
MD166255 1g dsm na 2.0 DOHC ECU, has been rebuilt but they didn't do a great job on replacing the caps $12
1g dsm large mitsu center caps $10
1995 3000GT manual shifter assembly $35
1995 3000GT leather wrapped wheel and airbag in great shape, spline will also fit 3g csm's $25
Expo 15/16" master cylinder, great upgrade for csm's with twin piston front calipers $25
Intrepid and 300m coil for custom coil on plug setups, some have the mounting holes across from each other and some are diagonal $20 for a set of 4
 Post subject: Re: Misc parts 10/07/11
PostPosted: Fri Oct 07, 2011 10:26 am
Ill take the shifter bracket stuff
PostPosted: Fri Oct 07, 2011 11:05 am
Odd request, but I need the coil pack plug and CAS plug (harness side). Converting the CSM to 91+ stuff and that's all I am missing.
1989 Mirage Turbo - 11.7@119
PostPosted: Fri Oct 07, 2011 11:18 am
I can sell you the plugs I have above from the 91+ coil and cas for $9 shipped.
Sent you a pm redsleeper.
PostPosted: Fri Oct 07, 2011 4:17 pm
I almost want the cargo cover/speakers too.. hahah how much do you think it wojuld be to ship that?
PostPosted: Fri Oct 07, 2011 5:28 pm
Probably $20 through Fedex, maybe less.
PostPosted: Fri Oct 07, 2011 9:33 pm
I NEED THAT SHIFT LINKAGE!
PostPosted: Fri Oct 07, 2011 11:41 pm
Red sleeper has already paid for this one but I need to grab some parts on Monday for a few other members on here so I'll get one then. This particular yard had a few manual elantras the last time I was there.
PostPosted: Fri Oct 07, 2011 11:47 pm
I wouldnt mind taking the rear light bar & door skins off your hands.
92 Plymouth Colt (4g63t, fwd) DD.
05 Jeep Grand Cherokee Limited
(Hemi powered grocery getter) WIFES DD.
PostPosted: Sat Oct 08, 2011 8:21 am
If Red Sleeper doesn't grab the rear hatch cover I will take it. Let me know Chris.
PostPosted: Mon Oct 17, 2011 7:15 pm
colt ECU PM.
PostPosted: Tue Oct 25, 2011 7:23 am
bump
PostPosted: Tue Nov 15, 2011 10:07 am
bump
