It is currently Wed Oct 22, 2025 3:55 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
PostPosted: Wed Sep 28, 2011 2:48 am
Because Race Car
All prices are OBO and are without shipping. Actual shipping will be calculated at time of sale.
Fuel level sending unit w/o harness $25
Fuel Pump hanger with newer Walbro (190 I think) and -6 AN Feed/Return $100
Brand New Timing side motor mount $30
Cam gears (not sure what year/motor they are from; could be 1.6 or 2.0) $5/set or free with any purchase
Throttle Cables (I believe these are to use a 4G63 in a CSM because they came from Chris-rallyguy) $25 Only one left
Green top CAS $20 each
Another Green top with integrated harness $20
PostPosted: Wed Sep 28, 2011 7:06 am
Is the transmission mount of a 4g61t or just a regular 4g63t mount? Im looking for the transmission mount to do the 63t swap on my mirage 1.5
PostPosted: Wed Sep 28, 2011 10:04 am
Are the 1" master cylinders good for a twin piston caliper brake upgrade? If so I'll take one. I'll do some searching, I just wanted to get my name in to buy one.
PostPosted: Wed Sep 28, 2011 11:36 am
Because Race Car
RedTsi - The mounts are for a 4g63 2.0L swap
Shawn - These cylinders are what Chris was running with his 4 piston Wilwood setup. They will be sufficient for a DSM 2 piston setup. I have a couple of different proportioning valves I can throw in too.
PostPosted: Wed Sep 28, 2011 1:20 pm
Are you willing to part the mounts?,i need the transmission one.
PostPosted: Wed Sep 28, 2011 1:28 pm
Because Race Car
I would prefer to sell them together but I will separate them if there is no interest in the set. PM me your ZIP in PR and I'll get a quote out to you.
PostPosted: Wed Sep 28, 2011 11:35 pm
Because Race Car
Only 1 master cylinder left! Gaskets pending until Saturday.
Quotes out on a lot of this stuff so get it quick!
PostPosted: Sat Oct 01, 2011 3:14 pm
Because Race Car
Gaskets Sold!
PostPosted: Wed Oct 12, 2011 1:49 am
Because Race Car
Both masters sold now.
PostPosted: Wed Oct 12, 2011 7:08 pm
Interested in fuel level sender,
possibly the pump assy as well (can this fit a 92?)
And I will def take one throttle cable.
Regards,
-Shawn
MEMBER #1495
'92 Dodge Colt 63 swap (SOLD)
'92 Galant VR-4 (it's Alive!!)
'12 Forester (DD)
GONE:
'92 Plymouth Colt 12v 4M->5M
'90 Dodge Colt GL 8v 3A
'89 Plymouth Colt 8v 5M
'92 Galant LS
'92 Galant GSR
'93 Galant LS
'93 Galant S
PostPosted: Thu Oct 13, 2011 12:32 am
Because Race Car
Regards,
-Shawn
Pm'd
PostPosted: Thu Oct 13, 2011 1:01 am
so the throttle cable is different in a csm to run a 4g63?
PostPosted: Thu Oct 13, 2011 1:45 am
Because Race Car
Yes sir: http://www.4g61t.org/forum/viewtopic.ph ... ttle+cable
PostPosted: Fri Oct 14, 2011 11:42 pm
Because Race Car
LCAs and Expo Uprights SOLD
PostPosted: Mon Nov 07, 2011 10:29 pm
Did you sell the timing belt mount with the prothane insert?
