It is currently Mon Jun 03, 2024 10:57 pm
Post new topic  Reply to topic  [ 46 posts ]  Go to page 1 2 3 4 Next
 Post subject: 91 sedan swap.
PostPosted: Thu Aug 25, 2011 11:44 pm
Who's tried a 2g tank on their awd swap? It's a saddle type tank right, thoughts? TIA.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
 Post subject: Re: 2g awd gas tank
PostPosted: Fri Aug 26, 2011 10:05 am
Where would you put it? Are you using a 2g rear frame too? There's definitely no room for one in my car.
PostPosted: Fri Aug 26, 2011 12:51 pm
Well on a 2g it goes under the rear seat. I was considering putting it the same place on my sedan, where the old fwd tank was, under the rear seat. Im using the 1g awd subframe.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Fri Aug 26, 2011 4:18 pm
I don't know how much room is left with a sedan, but the boomerang takes up that area pretty completely in my hatch.
PostPosted: Sat Aug 27, 2011 3:59 pm
Thanks for the picture. I'll have to go a different route I guess. People on the internet seem to have generally low opinions of the 2g awd tank. Do you have a picture showing how low that 1g awd tank hangs?
Would you cosider mounting the stock csm tank back there?
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Sun Aug 28, 2011 1:06 am
The csm tank occupies the space where the FIRST section of driveshaft resides as it exits the rear diff. You cannot use it
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Sun Aug 28, 2011 9:26 pm
Yeah I'll stick with the 1g tank. It's the hump I don't like but using one simplifies the fuel pump and level sender so much. A cell would be overly complicated for a street car.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Tue Sep 06, 2011 1:10 am
Appologies for the crappy IPhone media.
Rims I will run
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
 Post subject: Re: 91 sedan swap.
PostPosted: Sun Mar 25, 2012 9:10 pm
Is this wheel too far forward? Should I put the rear subframe and axle 1/2" further back? This is on a sedan and I'm not planning on shortening the drive shaft.
It's tacked in now. I'll be swapping an awd tranny next to set up the driveshaft.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Sun Mar 25, 2012 11:39 pm
Im not 100% sure on this but my buddy told me that some people were using the vista and expo tanks. I never really verified it though.
1991 Plymouth Colt - Project
PostPosted: Mon Mar 26, 2012 8:59 am
I picked up a fuel cell. I also have a 1g awd tank. I'll probably go with the cell.
Any comments on the rear axle placement? Too far forward? These are16"x7" rims with a 38 offset. The tire is 195/50. I measured from the tire to the lower lip of the fender. It was 2" at the front and more than 3" at the back.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Mon Mar 26, 2012 9:20 am
When I initially tacked up my rear, it was in the same exact position as yours. Though it won't affect anything I moved the subframe back so the wheel was centered up. I couldn't stand it looking like that at all.
PostPosted: Mon Mar 26, 2012 12:59 pm
Your wheels look like they are in the correct spot. I used the stock csm fuel tank with my swap, just built a custom rear mount and filler neck.
PostPosted: Mon Mar 26, 2012 1:04 pm
Thanks, I'll be swapping out the FWD transmission next and sizing up the drive shaft. Then I'll see about getting the rear back a bit. I had to dent the rear floor some because the boomerang hit it.
Was your swap on a hatch?
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Mon Mar 26, 2012 3:20 pm
Yes this is was on hatch, I guess you may have no choice though with using the stock driveshaft lengths.
